Old 04-01-2011, 10:46 PM   #1
nublood1
Any cheap or free mods for a 350?
I have a 1975 C/10 with a stock 350. Are there any restrictive parts that I can remove, or any way to get more out of the engine? I know it may sound like a dumb question. But finances are an issue at the moment however I'm just itchin' to do SOMETHING to her.
nublood1 is offline   Reply With Quote
Old 04-01-2011, 10:47 PM   #2
lilpoindexter
lilpoindexter's Avatar
Re: Any cheap or free mods for a 350?
If you have a timing light, try playing with the timing to see if performance increases...you may experience pinging, however.
lilpoindexter is offline   Reply With Quote
Old 04-01-2011, 11:02 PM   #3
chevymotocross
chevymotocross's Avatar
Flip the air cleaner lid
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch
chevymotocross is offline   Reply With Quote
Old 04-02-2011, 01:07 AM   #4
bigwheel15
bigwheel15's Avatar
A carb spacer is cheap and easy power
bigwheel15 is offline   Reply With Quote
Old 04-02-2011, 03:24 AM   #5
GMC Guy
GMC Guy's Avatar
open air cleaner, carb spacer, and a timing adjustment. maybe some 91 octane and run a bottle of seafoam though the motor
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 04-02-2011, 07:45 AM   #6
big10ratrod77
big10ratrod77's Avatar
2 or 2 1/4 inch duel exhaust with a turbo style muffler, mine ran about 250 for everything and it picked up a good bit of power also adjust you carb and you can put smaller meetering rods in the back of the carb if it still has the stock q jet. a good tune up helps to and swap and swap it over to hei if it dosent have it. it would also help if you gave us a budget idea to.
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 04-02-2011, 10:00 AM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
i see aluminum intakes sell on cl for $40 all day... I'd get one of those.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 04-03-2011, 12:32 AM   #8
willstruck
Do carb spacers really make a difference? I was going to make one once I started working at a machine shop again. might just buy one...
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 04-03-2011, 01:22 AM   #9
broey
Square
broey's Avatar
Check out Yezzi's thread. You could do something like THIS Just a lot of work and a little money for tape and paint.
Squarebody Syndicate
broey is offline   Reply With Quote
