Old 03-29-2011, 09:13 PM   #76
willstruck
Re: Where does your exhaust exit?
Anyone make their own x-pipe? Seems like it should be pretty easy to cut an oval out of 2 pieces of 45 degree mandrel pieces from summit or whatever, and weld them together. Since it's short pieces, you would be able to get a tool in there to clean the welds up even. $14 roughly, instead of $100...
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 03-29-2011, 09:46 PM   #77
motornut
78K & 79C Jimmys
motornut's Avatar
on my gold truck i wanted to get the two pipes bent in to overlap )( <-like that
close enough they would bang each other,once it was pieced it could be tacked and removed cut and welded properly
was too many $$ as they wanted to go up and around being 4X4,might work better 4X2 tho
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-30-2011, 08:39 PM   #78
RAMJAM
RAMJAM's Avatar
lake
RAMJAM is offline   Reply With Quote
Old 03-30-2011, 09:17 PM   #79
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
True duals 3" all the way back
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 03-31-2011, 12:42 AM   #80
Hiluxxulih
Hiluxxulih's Avatar
My 86 K20 is a factory dual exhaust so far as I can tell , and it looks to be original and in good shape and no factory catalytic converters I assume its because its a heavy duty 350
Hiluxxulih is offline   Reply With Quote
Old 03-31-2011, 04:02 AM   #81
Kerlijah
Kerlijah's Avatar
Just a temporary setup on mine till I can afford Flowmaster 40s, right now I've got stock manifolds and cat, with a good ol Cherry Bomb glasspack and single exhaust exiting in front of the left rear wheel. Sounds nice, looks great, but way too quiet for my tastes. Cant wait for the 40s!!
Kerlijah is offline   Reply With Quote
Old 03-31-2011, 06:45 PM   #82
cr34t3d_by_d4rkd3n
out the tail pipe?
cr34t3d_by_d4rkd3n is offline   Reply With Quote
Old 03-31-2011, 07:41 PM   #83
LOW1TON
Here are my weed burners.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 04-02-2011, 08:12 AM   #84
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Very Nice!
Grande Rojo is offline   Reply With Quote
Old 04-02-2011, 08:14 AM   #85
Grande Rojo
paper or plastic?
Originally Posted by coater View Post
ROJO, Do you have a full pic or your truck? Like the look of rear tire and wheel. Would like to see it.
I'll try to take some pics today for everyone that asked.
Old 04-02-2011, 09:36 PM   #86
RAMJAM
RAMJAM's Avatar
Sick!!!!
Old 04-03-2011, 10:18 AM   #87
S10Fan
Old Heap Driver
Cool! no, Hot!, Well, you know what I mean!
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 04-03-2011, 10:34 AM   #88
Codys87
Codys87's Avatar
Here is mine...
85 SWB 6.0 swap/heads/cam/pistons/headers/4L60E/3.73 posi/one piece windows/working towards air bags
04 Avalanche/9 inch lift/wheels 20x12 with 35 inch tires
Codys87 is offline   Reply With Quote
Old 04-03-2011, 10:37 AM   #89
S10Fan
Old Heap Driver
Originally Posted by Codys87 View Post
Here is mine...
Nice Job!
Bryan
Old 04-03-2011, 10:43 AM   #90
Codys87
Codys87's Avatar
Thanks! I still have some work to do on them, cause I was thinking about making them tuck more to where the bottom of the tip would be flush with the bottom of the truck.
Old 04-03-2011, 05:26 PM   #91
Pop's C-10
Pop's C-10's Avatar
Here is mine...
I like tha way you have tha tips notched into tha bed side..
Pop's C-10 is offline   Reply With Quote
Old 04-07-2011, 10:32 PM   #92
redneckchevy
redneckchevy's Avatar
headers in to 2.5 True duel's, no cats.
redneckchevy is offline   Reply With Quote
Old 05-23-2011, 01:40 AM   #93
DetroitDan
DetroitDan's Avatar
I just got around to cutting my old mufflers and tailpipes off, put on two slip-on 2.5 Thrush glasspacks (same as Cherry Bombs) Sounds wicked at idle, pretty good going down the road and not bad at all at highway speed (55 mph, what can I say I've got 4.10s and a 3 speed) I do have a pretty noisy drone at about 35, which is where much of my driving is done, so I'm looking to add some tailpipes. The mufflers right now exit just before the rear axle, but past the front of the rear tires, so I couldn't 90 them out the sides in front of the tires. I also have some sort of bracket in the way keeping me from going straight back on one side, but I might cut it and adjust it to clear. I don't have the tools to bend a pipe around the bracket, so whatever I have to do is going to be made from off the shelf parts. Advance has 18 inch pieces and 45s or 90s, so depending on how far back the 18 inch gets me I may try for the 45. I don't think 18 will get me far enough to turn 90 and come out behind the rear tires.
Reason I came looking for this thread again was to see if I could figure out which would be the best way to do the tailpipes. Straight back would be easiest amd looks good, but I never liked that because of bashing into frozen snowbanks when backing up plowing, and like someone else mentioned having to shut the truck off to hook up a trailer. I like the 45 degree look, and the 90 also.
I'm wondering if the side exit may sound even cooler at a lopy idle because you're only hearing half the cylinders at once, making an even lopier sound.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 05-23-2011, 11:52 AM   #94
parrisc19844x4_468
parrisc19844x4_468's Avatar
Originally Posted by Lost 40 View Post
Looking to see pics of what different things people have done with their exhaust on their trucks. Her are two pics to start...
just behind the wheels.
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 05-23-2011, 12:56 PM   #95
Redcap
Mine currently dump under the bed.
Redcap is offline   Reply With Quote
