Old 04-04-2011, 10:09 AM   #1
81ratrodc10
house of chevy's
81ratrodc10's Avatar
tranny ?
will a 5spd tranny from an 87 trans am with with a 305 botlt up to my c10 with a 305 thanx
1987 m1028 cucv d30
2001 chevy s10
2000 honda shadow sabre 1100
"it's going to be an interesting ride home"
81ratrodc10 is offline   Reply With Quote
Old 04-04-2011, 02:18 PM   #2
Pop's C-10
Pop's C-10's Avatar
Re: tranny ?
yes..
Pop's C-10 is offline   Reply With Quote
Old 04-04-2011, 08:11 PM   #3
81ratrodc10
house of chevy's
Re: tranny ?
does any one know what model it would be and how hard of a swap from a th350 to it
1987 m1028 cucv d30
2001 chevy s10
Old 04-04-2011, 08:20 PM   #4
Mikec10
Mikec10's Avatar
Re: tranny ?
Shouldn't be too hard, you'll just have to cut a hole in the floor for the shifter, you might also need a different length drive shaft.
Mikec10 is offline   Reply With Quote
Old 04-04-2011, 08:21 PM   #5
cableguy0
Re: tranny ?
Its more than likely a t5. Definately not the strongest tranny out there. You will need to move the transmission crossmember and have the driveshaft shortened. You will have to get the clutch dealt with. Im pretty sure the car has a hydraulic clutch. So you will have to mount the clutch master cylinder,figure out the pedal assembly etc. You will also need a flywheel and the clutch setup.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-04-2011, 08:24 PM   #6
81ratrodc10
house of chevy's
Re: tranny ?
i have free run of all the parts off the car would they all match my motor if my buddy doesnt sell it by this weekend i can have whatever off it
1987 m1028 cucv d30
2001 chevy s10
Old 04-04-2011, 08:41 PM   #7
cableguy0
Re: tranny ?
Physically everything is the same. its a bolt in deal as far as engine to transmission. Everything else will have to be fabbed up.
Old 04-04-2011, 08:44 PM   #8
81ratrodc10
house of chevy's
Re: tranny ?
is it a good idea to wast my time changing it all over for a t-5 and not something better
1987 m1028 cucv d30
2001 chevy s10
Old 04-04-2011, 09:01 PM   #9
ajester
ajester's Avatar
Re: tranny ?
I would look for something stronger but that's just me.
I changed my truck from a diesel/auto to a gas/manual it's not all that hard, but the pedal linkage was a pain.
Aaron
85 k10 4" lift 454 in the works
ajester is offline   Reply With Quote
Old 04-04-2011, 09:09 PM   #10
lilpoindexter
lilpoindexter's Avatar
Re: tranny ?
I'm putting a T5 out of a 305 Camaro in my '78 C10 with a straight six 250. I'm putting an s10 tailhousing on it, and a different bellhousing so the trans is straight up, not at 17 degrees (or whatever) like in the F body. I kept the pedal assembly from the camaro...I'm defintely going with a hydraulic clutch, but I'm not sure yet if i want to use the camaro stuff, late square body or 88+ hydraulics. On a thread in the FAQ someone ordered a complete hydraulic linkage from LMC and bolted in it. I really don't like the old school mechanical linkage, and can't wait to pitch it.
EDIT:
Read the t5 swap threads in the engine section
lilpoindexter is offline   Reply With Quote
Old 04-04-2011, 09:10 PM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: tranny ?
Something the other answers are passing over is the flywheel. The 87 model 305 engine in the Camaro will have a 1 piece rear main seal engine which uses a different flywheel than earlier 2 piece seal engines. If your truck's 305 is earlier, the flywheel won't work and you'll need to get a flywheel to match your engine.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 04-04-2011, 09:19 PM   #12
lilpoindexter
Re: tranny ?
Do you know what year the one piece seal started?
I have the flywheel still in my 250, and I also kept the flywheel from the '83 Camaro I got the trans from.
Old 04-04-2011, 09:31 PM   #13
Tx Firefighter
Re: tranny ?
87 began 1 piece rear main seals. 55-86 SBC engines had 2 piece seals. Flywheels do not interchange between the two due to crankshaft flange differences.
