Old 04-04-2011, 10:22 AM   #1
low_84_inchaska
low_84_inchaska's Avatar
fuel system questions and issues.
hey guys i got my truck running on saturday but ran into a few issues...
1. seems my fuel rail and injectors got some varnish in them cause i was having issues with fuel getting to the cylinder and i took them off and there is some varnish residue in the injectors, i tapped it out of them...is there a way to get the injectors and rail cleaned out?
2. my pressure side russel fuel quick fitting came off during testing and sprayed gas all over...this has happened twice so i ordered another one. has anyone had this issue before..i am going to install the new one and let it pressure test for an hour..this really freaks me out...especially if i was going down the highway and the thing popped off with a hot motor. It never went on as easy as the return fitting did,,i hope i had a defective fitting.
my build http://67-72chevytrucks.com/vboard/s...d.php?t=367330
84 short-wide 2wd. 99 5.3 vortec, built 4l60E, schoenfelds, bubb tune, cyber grey metallic
10 camaro ss/rs, 6spd manual, leather, loaded, cyber grey metallic
low_84_inchaska is offline   Reply With Quote
Old 04-04-2011, 10:50 AM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: fuel system questions and issues.
1. You can/could soak then injectors in something like seafoam to see if it helps de-varnish them. There are also a large number of companies who will professionally clean and flow your injectors.
2. Make sure you have the right sizes (the 3/8ths will fit and kind of "snap" over the 5/16ths line, but not tightly. I almost did this when hooking mine up). Also make sure the plastic peice inside of the fitting isn't broken. You probably just had a bad fitting but better to be safe.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-04-2011, 11:23 AM   #3
low_84_inchaska
yes i had the right connector, the thing is it never really snapped like the return line and it was very hard to put on....just didnt feel right..if it fails pressure testing again with the new fitting i am just going to cut it off and put a compression to an fitting on there.
will the seafoam hurt the electronics?
Old 04-04-2011, 12:08 PM   #4
ls1nova71
ls1nova71's Avatar
X2 on the Seafoam. It won't hurt the electric parts. Let them soak over night and re-install and you should be good to go.
ls1nova71 is offline   Reply With Quote
Old 04-04-2011, 03:09 PM   #5
low_84_inchaska
have you guys seen the videos on youtube where they take a switch, 12v ps, a fuel injector connector and a cut off syringe and use them to reverse flow and normal flow clean the injectors...that looks like the way to go man.!!
now to find a fuel injector connector with about 6 inches of wire on it?? any ideas?
Old 04-04-2011, 04:40 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
whoa nelly, take a step back from the compression fittings. I had the same thought (since it's easier than going tube nut ->coupler_> an) however if you read the fine print, those are NOT for efi. They are only rated for ~25psi. I saw them on summit without that rating, but a different wholesaler has the "25psi" limit listed on the product page.
Old 04-05-2011, 07:58 AM   #7
low_84_inchaska
here is what i was talking about....i know a lot of guys use these on efi...but that doesnt mean it is right.
http://www.summitracing.com/parts/EAR-165006ERL/
Old 04-05-2011, 10:10 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
note that it says "50psi max pressure" (i misquoted and said 25psi). Technically our fuel systems run at a higher pressure than that. I understand that the fitting will "probably hold", but still probably not the greatest idea.
Best to either a. use a sleeve and tube nut and make a 37* flare on the line, then attach using regular AN fittings...but you need a 37* flare tool for this.
b. go from 3/8 tube nut ->female to female coupling-> 3/8 male to -6 AN adapter. This leaves you with all threaded mechanical connections, which will hold well over and psi the rail would ever see.
Old 04-05-2011, 10:37 AM   #9
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Pretty sure the plastic clip would be at fault on the fuel line.
http://www.autozone.com/autozone/acc...er=429541_0_0_
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-05-2011, 03:05 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
low_84, those compression - an fittings now have me very curious.
The 50psi rating is the only thing that has me thrown off. I checked around and it seems like some people ARE using them on high pressure efi, but just as many saying to stay away. If anyone else has experience with these please chime in. the risk of an engine compartment fire is not something I look forward to.
Old 04-07-2011, 08:32 AM   #11
low_84_inchaska
used the seafoam, replaced the quick connect fitting on the fuel rail...she runs like a raped ape now..very responsive...works great.
thanks!
Old 05-05-2011, 05:58 PM   #12
usmcchevy
usmcchevy's Avatar
Found this over at LS1tech after I noticed I could pull mine off way too easy.
http://www.ls1tech.com/forums/conver...-fittings.html
Build thread
LSx Swap FAQ index
Old 05-06-2011, 11:16 AM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I saw that earlier as well. I used those on my rail, so I have to watch real close when I go to pressurize the system for the first time this week. Hope i got the good ones.
