Old 04-04-2011, 10:34 AM   #1
BigRob
Intro and Question Trans Hard shift?
Hi All
My name is Rob Mannon, and I am new to this board. I live just outside nashville Tn, and have been a motorhead from birth. I purchased a my first square this weekend, and am stoked about the resto. I do have one concern that is over my head.
I have an 87 SWB 350/700r. When I put it into gear (f or r ) it SLAMS, and when shifting from 1-2 it is pretty hard but bearable. My main concern is the when I put it in gear. Any thoughts?
BTW I have joined forums before for my other rides and this one has more info and pictures than any of the others. Kuddos to the moderators
BigRob is offline   Reply With Quote
Old 04-04-2011, 02:43 PM   #2
erikgto
Re: Trans Hard shift?
Got the same problem with my '86.
It's worse putting it in Drive
Haven't had the time to take it to a trans specialist yet......
U-joints, engine & transmounts are new..
1972 GMC 2500 Sierra 350
1971 Pontiac LeMans Sport 400 GTO/Judge Clone
1970 Pontiac GTO 400 convertible restoproject
1970 Pontiac Bonneville 455 convertible
erikgto is offline   Reply With Quote
Old 04-04-2011, 03:11 PM   #3
jchav62
1962 C-10
jchav62's Avatar
Hello Rob. Welcome to the boards.
My brother in law had the same problem with a 700r4 after a rebuild. The problem was a sticky governor. Luckily in his case, it fixed itself after driving it bit. I'm sure some transmission gurus will chime in with some good advice for you.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-04-2011, 03:37 PM   #4
87fleetsidedude
87fleetsidedude's Avatar
My 305/700r4 does the same thing, almost like theres a shift kit or something, but i know there isnt. im going to check mounts and everything this weekend.
1987 V10. 305, Th-700R4, (dail driver at home, work in progress) my baby
1967 C25. 250 inline 6, muncie 4 speed, dana 60 (project truck work in progress)
2010 Colorado. Inline 5 (mom's truck)
2004 1/2 ton. 5.3 Vortec (dad's truck)
1995 oldsmobile cutlass supreme. 3.1 v6 (daily driver at college)
87fleetsidedude is offline   Reply With Quote
Old 04-04-2011, 03:38 PM   #5
jitteryguy
GoatLube Experss
jitteryguy's Avatar
welcome abaord ! I live in Clarksville when I'm on the side of the planet.
a few question's: does the truck seem to idle high ?
are the Ujoints in good shape ? have some one hold the brake with the truck off and in nutral, see if there is any slack in the Ujoints.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 04-04-2011, 08:10 PM   #6
BigRob
It does seem to idle high, but the 1-2 shift put me off of that trail. I guess there could be two issues in one. What would cause it to idle high vacuum leak? Tps? It has been so long since I have had fuel injection that I can't remember the quirks.
Old 04-04-2011, 11:58 PM   #7
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Your RPMs are too high. Check the timing. Reset it to zero. You can add a few degrees for performance. Check for engine codes. You'll find great TBI info here http://www.cfm-tech.com/GM_tbi_tuning_tips.htm
Welcome to the board.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
