04-04-2011, 02:39 PM | #1 |
Used a/c compressor
Found a used a/c compressor, but can you rebuild the used ones or is it better to buy a new one? also its out of a 72 and mine is a 68, will it work? thanks
04-04-2011, 04:15 PM | #2 |
Re: Used a/c compressor
Buy a new one. No question in my mind.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
04-04-2011, 06:15 PM | #3 |
Moderator
x 2
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-04-2011, 07:05 PM | #4 |
I am pretty sure it is very difficult to find a new one these days. The ones I have found have all been rebuilt. That being said I would buy a new/rebuilt one X3. I made the mistake of using a used one because I wanted it to look original/old paint like everthing else under the hood, and not long after I put $80 of r-12 in it the compressor went bad.
72 Cheyenne Super 80 Silverado Blazer 2wd |
04-04-2011, 07:17 PM | #5 |
Thanks guys. New one it is.
04-05-2011, 02:53 AM | #6 |
Moderator
If you get a new one, I recommend an A/10 replacement from Old Air products. It is NEW, not rebuilt. The rebuilt A/6 will more than likely leak at the front seal. The 4 I went through did Just like Jason experienced above. The A/10 looks very similar to the A/6 and bolts directly to the factory brackets, and is more efficient. You can use R-12 or R-134. I finally put one in my truck , and had zero problems after that. A/C is not cheap!
You can get a rebuilt A/6 from any parts house for around $150...it will eventually leak. I had a local shop source a new (NOS) A/6 compressor and it was $800 The A/10 runs around $350-$400
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 04-05-2011 at 02:58 AM. |
04-05-2011, 04:48 PM | #7 |
I use used A-6 comp. all the time. They are so rugged you seldom get a bad one. You can get them anywhere from free to $35.
