04-05-2011, 12:32 AM | #1 |
rough idle help
So I took out the idle air control and broke it as i was putting it back in. I went out and bought a new one along with a new temp. sensor and its a little better. THe idle still goes up and down the minute i turn it on from a cold start. After a little time it idles perfect. Just to make things a little easier....Its a 350 with tbi with a butt load of sensors.
Any ideas?
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 |
04-06-2011, 09:13 AM | #2 |
Re: rough idle help
blah blah blah
04-06-2011, 09:48 AM | #3 |
Re: rough idle help
I know this may not seem like any help, but you should pm RFMaster on here and see what he says. You should also try a search for tbi idle problems or something related to tbi, I know there are quite a few good replies already on the board for that. Sorry I can't be specific on how to fix your problem, I am still learning the ins and outs of tbi tuning myself.
04-06-2011, 10:36 AM | #4 |
Arrived on a Pale Horse
Re: rough idle help
There's two temp sensors. One for the computer and one for the gauge.
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
04-06-2011, 06:08 PM | #5 |
Re: rough idle help
no sh!t? wonder where the other may be cause i didnt know that. Maybe thats the one. Thank you. Now for the second temp. sensor search.
04-06-2011, 06:27 PM | #6 |
Slots go on anything!
Re: rough idle help
The CTS (coolant temp sensor, for the ECM) is on the intake, usually right in the front, by the water neck. The Temp sender (for the gauge) is in the driver's side head, between the #1 and #3 exhaust port.
1974 Jimmy- 5.3/4L80e/NP241 |
04-06-2011, 10:05 PM | #7 |
Re: rough idle help
also if you did change the right temp sensor if you didnt disconect your battery for about minute so it clears all codes the ECM will clear codes on its own with 50 ingnition cycles (I think its 50) ingnition cycles = ON/OFF
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG |
