Old 04-06-2011, 01:04 AM   #1
61apachespeed
accel dual points help
i just got a old accel dual points dis. ok it has two wires one black one red. i think the red goes to the black side of the coil and the red side of the coil gets hook up the batt. but where does the black wire go???
61apachespeed is offline   Reply With Quote
Old 04-06-2011, 01:13 AM   #2
Captainfab
60-66 Nut
Re: accel dual points help
Which model is is? Is it the 37100? It's been a long time since I've messed with a dual point, but if I remember correctly, both the red and black connect to the dist side of the coil. Each wire is for one set of points. The factory wiring included a disconnect on one of the wires, so that you could disable one set of points so that you could set the dwell on one set of points. Then you reconnect the wire to the other set of points and set the total dwell. You might go to Accel's website and see if they have the installation instructions for your distributor. I know I've found them for some older electronic distributors.
Old 04-06-2011, 01:27 AM   #3
61apachespeed
its a 30100t it looks like you can ajust the dwell with a running motor.
Old 04-07-2011, 12:22 PM   #4
bama63
bama63's Avatar
the captain is again 100% correct
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
