Disc Brake Help!
I have a set of McGaughys drop spindles PN 6072 for the truck (65 with an 84front crossmember) and Im kinda stuck!
Are these spindles for 1.25" rotors only? What years C10s came with the 1.25" rotors? Thanks Again For the Help!
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
BMW & ASE Master Certified
Re: Disc Brake Help!
the parts house will ask you what rear brakes you have... 2" rear brakes = 1" rotors, and the other... 2+" rear drum is the 1.25" rotor.. that simple
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
67-72 parts collector,…
![]() Join Date: Nov 2002
73-80 had the 1.25" rotors.
Some 81-87 had the 1.25" rotors. Some 81-87 had the "light duty" 1" rotors. Your spindles will use 1.25" rotors. Just tell the parts guys you have a 73, and you will be fine.
