Old 04-06-2011, 10:02 PM   #1
motiveauto
motiveauto's Avatar
Rotors or Axles?
I just finished my front end swap (84 crossmember onto my 65 C10) and here is the dillema im having
Id like to keep my original steel wheels but Im pretty sure they wont fit over the disc brakes.
Should I convert the truck to 5 lug or should I get the 6 lug rotors for the front end?
What do you guys think?
86 K20 6" lift
66 C10 LS2 T56
1947 Ford Rat Rod
Softail Deluxe
Softail Chopper
motiveauto is offline   Reply With Quote
Old 04-06-2011, 11:33 PM   #2
1966JSM
Re: Rotors or Axles?
6 lug rotors
1966JSM is offline   Reply With Quote
Old 04-07-2011, 01:23 AM   #3
Captainfab
60-66 Nut
If your 6 lug wheels are the original style 15" wheels for your truck, they won't work with disc brakes. If they are 16" they might work.
Old 04-07-2011, 11:50 AM   #4
jimmydean
jimmydean's Avatar
I used some 6 lug ralleys off a 4x4 when I swapped the discs on the front of my '69. The rear lip on the newer steel wheels clears.
Here's a shot from GMC Pauls showing the 15" wheels that will fit the disc front (not the big brakes)
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-07-2011, 08:35 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Here's an earlier thread that may provide some helpful information. Fyi if you do install the 6 lug rotors, the stock wheels "may" fit over the calipers if they are original 5" or 5 1/2" wide rims. Wheels this skinny might fit because the back side of the rim is so shallow. It just depends, some will fit while others won't.
http://67-72chevytrucks.com/vboard/s...c+brake+wheels
Old 04-07-2011, 08:54 PM   #6
bubba327
HOW long until spring??
bubba327's Avatar
I went for the 6 lug rotors and stayed original when I swapped front crossmembers . My wheels are aluminum aftermarket 15" and they clear the GM calipers nicely. I am running 235/60/15 on a 9" wheel on all four corners..
I put discs on my Chevelle and went through this with the 14" wheels. ....
Bolt one up and check it out..
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
