Closed Thread
Old 04-06-2011, 10:23 PM   #4401
Ru5tyNut5
Ru5tyNut5's Avatar
Re: How about some pics of '73-'87 Short Beds
Originally Posted by JIMMYRAY31B View Post
'75 C10
welcome JimmyRay, I see you aren't too far up the road from me...Always nice to see more Washington boys.
'55 Pontiac - Project
'63 GMC - Project
'76 Chev stepside rust bucket - Bagged daily driver
Project Ru5tyNut5
Ru5tyNut5 is offline
Old 04-07-2011, 02:30 PM   #4402
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
Originally Posted by 3r!c84 View Post
3:42 airborne race posi
315/35/17 25inch tall tire. too small for me. im going to a 27-28 inch tall tire when i get new rear tires.
Thats a nice setup, im still debating wether to go back to 315/325 drag radials about a 30-31" tire and some decent front runners
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline
Old 04-07-2011, 03:06 PM   #4403
3r!c84
Badass
3r!c84's Avatar
what part of florida are you in?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline
Old 04-07-2011, 03:35 PM   #4404
383Chevy
383Chevy's Avatar
Englewood below bradenton
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
383Chevy is offline
Old 04-07-2011, 03:37 PM   #4405
3r!c84
Badass
3r!c84's Avatar
oh alright im over in west palm beach
-00 Saturn 5spd
1/4:13:90
3r!c84 is offline
Old 04-07-2011, 03:46 PM   #4406
383Chevy
383Chevy's Avatar
I went over there once to get a 1980 camaro tube chassis roller
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
383Chevy is offline
Old 04-07-2011, 09:06 PM   #4407
87 chevy silverado
i use to live in manatee. thats were my truck spent most of its life till i move d up her and it followed a year later. sorta miss it but glade i moved
87 chevy silverado is offline
Old 04-08-2011, 05:12 AM   #4408
csaw9014
Re: How about some pictures of '73-'87 short beds
tomorrow im gettin a 87 c10 with 4 speed...its a 4x4 but i wanna lower it like this. Any suggestions? i like your setup.
csaw9014 is offline
Old 04-08-2011, 10:27 AM   #4409
wiggins
wiggins's Avatar
if its a 4x4 dont lower it go higher!
Preserving American History one truck at a time.
wiggins is offline
Old 04-08-2011, 11:54 AM   #4410
csaw9014
well i have 2 4x4 trucks one on 40s and the other is my daily driver on 32s. i wanna lower this one and eventually drop in a bigger motor
csaw9014 is offline
Old 04-08-2011, 11:40 PM   #4411
justcuz
justcuz's Avatar
Originally Posted by VegasBruce View Post
My 73 Stepside
Props on the 73 stepside. I remember when there were tons of these guys running around in the desert. Walker Evans started a fad with his yellow pickup.
justcuz is offline
Old 04-08-2011, 11:51 PM   #4412
VegasBruce
VegasBruce's Avatar
Thanks, 25 years ago, I spent a lot of time in the desert with this one.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline
Old 04-09-2011, 11:59 AM   #4413
justcuz
justcuz's Avatar
I did so many of these back in the mid to late seventies I still remember the Chevy part number for the front springs we used 328101. I think they were big block crew cab springs. We would box the LCA's tie them together with tie bars through the LCA pivot bolts, build shock hoops and run 2 shocks off the UCA. When I built mine I used 3/4 ton A arms and bushings because they were lubable and all metal, not the stock 1/2 ton rubber ones. Then run a front skid plate from the crossmember to the end of the frame horns with a tube bumper similar to yours. We would weld a truss on the rear 12 bolt and add a second set of shocks out back too. Usually took the rear springs and added 2 long leafs and removed the overload then had them rearched 2" over stock. That was pretty much it except for either a 12 bolt posi or a mini spool. Usually ran 3.73's or 4.11's with Winston Fun and Muds, Desert Dawgs, Gates Commandos or Armstrong Tru Tracs. All were about in the 31 or 32" range. The budget guys would run Jeep take offs, Goodyear Suburbanites, about a 29" tire as I recall.
justcuz is offline
Old 04-09-2011, 04:48 PM   #4414
VegasBruce
VegasBruce's Avatar
Mine was put together in the early 80's. Same springs didn't do the shocks though, should have all the stockers where ripped out of the frame. Poly bushings in the front, due to be changed now. I'll build the LCA ties while its apart, maybe redo the skidplate.. I've always run 33's on it, with 8" rear and 7" front rims. I need to get the beard seats reupholstered and back in. They are so old Beard doesn't have the patterns for them.
Bruce
Old 04-09-2011, 06:52 PM   #4415
Yezzi
Yezzi's Avatar
New pics of O.J.
Yezzi is offline
Old 04-09-2011, 06:55 PM   #4416
Yezzi
Yezzi's Avatar
Check out the hawk
Yezzi is offline
Old 04-09-2011, 07:49 PM   #4417
VegasBruce
VegasBruce's Avatar
Sweet, nice truck yezzi.
Bruce
Old 04-09-2011, 09:54 PM   #4418
richielicious
here is my baby. im still workin on it, but since i got it to drive it, i havent even used my 07 silverado anymore
richielicious is offline
Old 04-10-2011, 01:54 AM   #4419
Mikec10
Mikec10's Avatar
Yezzi, truck is great! What are your drop specs?
Mikec10 is offline
Old 04-10-2011, 02:02 AM   #4420
Yezzi
Yezzi's Avatar
Mcgaughys 2.5" drop spindles mcg33153, 2" low front coils mcg33128, rear drop hangers 3-4" mcg33155, 1-2" drop shackles mcg33131-s, and McGaughys front and rear shocks mcg1350 and mcg1850. I also took two leafs out.
Yezzi is offline
Old 04-10-2011, 10:17 PM   #4421
wiggins
wiggins's Avatar
Beautiful ride, very nice look. Is that ruck unrestored or just restored back original?
wiggins is offline
Old 04-10-2011, 10:33 PM   #4422
Yezzi
Yezzi's Avatar
Original paint
Yezzi is offline
Old 04-11-2011, 03:28 AM   #4423
franky69c10
chevy runs deep
franky69c10's Avatar
Look'n good yezzi
RAIDER NATION
1969 c10 swb soon 2 b on the road...
My LWB is a SWB now
http://67-72chevytrucks.com/vboard/s...d.php?t=498241
franky69c10 is offline
Old 04-11-2011, 09:48 AM   #4424
jchav62
1962 C-10
jchav62's Avatar
Nice photography Yezzi!!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline
Old 04-11-2011, 10:54 AM   #4425
wiggins
wiggins's Avatar
How many miles are on that truck? Ready to sale?
Original paint
wiggins is offline
Closed Thread
