Old 04-07-2011, 02:13 PM   #1
telly
telly's Avatar
Valve Spring Keepers
I'm attempting to change the valve stem seals and I have the spring compressed, but the keepers don't want to release. Any ideas?
Thanks, Telly
1970 C10 Stepside
1980 Camaro Berlinetta
1972 C20 Flatbed
telly is offline   Reply With Quote
Old 04-07-2011, 02:34 PM   #2
AustinScott
AustinScott's Avatar
Re: Valve Spring Keepers
give them a tap, they will pop right off.
AustinScott is offline   Reply With Quote
Old 04-07-2011, 03:46 PM   #3
telly
telly's Avatar
Maybe I don't have the springs compressed properly. They seem to be compressing upwards rather than downward toward the block, so they aren't releasing the pressure on the keepers.
Am I hooking up the valve spring compressor incorrectly?
Wouldn't you know...the camera battery is dead. I'll include pictures as soon as I have a charge.
1970 C10 Stepside
1972 C20 Flatbed
Old 04-07-2011, 04:02 PM   #4
tasian
tasian's Avatar
sounds like the springs are just sticking to the keepers/valves if the heads are off just hold the spring down and give the valve a tap with a hammer from the other side and if you have the heads still on the block then hit the spring compressor or the spring but don't forget to have something to stop the valve from falling in
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 04-07-2011, 04:02 PM   #5
telly
telly's Avatar
Just watched a YouTube video.
Maybe I have my problem figured out. I didn't push down on the spring to release pressure on the keepers. ROOKIE
1970 C10 Stepside
1972 C20 Flatbed
Old 04-07-2011, 04:05 PM   #6
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
telly, I've never used one of the type that I think you're using but I believe it can only work as you're describing: grabs the spring near the bottom and compresses it upwards against the retainer, right?
at that point you should be able to push the spring/retainer down towards the head to release the keepers. what are you using to hold the valve up?
oop, too late, you got it!
Larry
fleetsidelarry is offline   Reply With Quote
Old 04-07-2011, 07:06 PM   #7
cableguy0
The best thing to do is hit each spring with a soft face hammer before you try to compress the spring.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-07-2011, 08:21 PM   #8
telly
telly's Avatar
The Rookie is still showing thru...
Who can speculate as to what I've done wrong. I was only able to change the valve stem seals on the #1 because I couldn't get the other cylinders to TDC (or I didn't feel comfortable that they were at TDC). So I buttoned everything up and now it won't start. Help!!
And how do I know when the other 5 cylinders are TDC. It seemed easy for #1, but then I tried to get #5, then #3, and I just didn't feel good about it. It sucks to not know what you're doing!
1970 C10 Stepside
1972 C20 Flatbed
Old 04-07-2011, 08:28 PM   #9
cableguy0
did you hook up an air hose to spark plug hole to hold the valves up? If you dont charge the cylinder with air you will never get the valve springs off. The valve will keep falling into the cylinder.
Old 04-07-2011, 08:32 PM   #10
telly
telly's Avatar
I don't have an air compressor. I stuffed nylon rope into the plug hole to fill the space and hold the valves closed, but I don't think I got the other cylinders to TDC and that caused the problem of not being able to get the keepers out. ??? This is the first time I have attempted this.
1970 C10 Stepside
1972 C20 Flatbed
Old 04-07-2011, 08:35 PM   #11
telly
telly's Avatar
When I get cylinder #1 to TDC, is it as easy as turning the crank until the distributor points at the next plug? Is that how I find 5, 3, 6, 2, and 4?
1970 C10 Stepside
1972 C20 Flatbed
Old 04-07-2011, 08:35 PM   #12
cableguy0
The easiest way to know when a particular cylinder has the piston up is to remove the spark plug. stick a screwdriver in the hole and roll the engine over by hand until the screwdriver stops moving upward. Your no start issue is like the valve adjustment being wrong.
Old 04-07-2011, 08:39 PM   #13
telly
telly's Avatar
Thanks. I'll read up on the valve adjustment. And even though I'm frustrated, I'll give it another shot at getting the other valve stem seals done.
1970 C10 Stepside
1972 C20 Flatbed
Old 04-07-2011, 08:52 PM   #14
cableguy0
Just take a break drink a beer and relax for a few. It will go a lot smoother
Old 04-07-2011, 09:18 PM   #15
fleetsidelarry
Senior Car Nut
telly, remember that just because the piston is at TDC DOESN'T mean that it's at firing position (valves closed). If you were going by the timing mark on the damper you may have been on the wrong cycle and adjusted the valves wrong. If you had the distributor rotor pointed at the #1 position on the cap, you should have been OK. make any sense?
Larry
Old 04-07-2011, 11:30 PM   #16
telly
telly's Avatar
Thanks Larry. It makes perfect sense. I went back and took off the distributor cap and marked all the positions. Seems to be making the work go smoother. Quitting for the evening (6 of the 12 seals replaced) and will finish cylinders 6, 2, and 4 in the morning.
Thanks to everyone for the advice. I'll post the results tomorrow (sleeping with my fingers crossed).
1970 C10 Stepside
1972 C20 Flatbed
Old 04-08-2011, 07:13 PM   #17
telly
telly's Avatar
I got all the seals changed and they sure needed it. The old ones were hard and brittle. But now the truck won't start. It will turn over but it won't run. Any ideas as to what I screwed up? Man, I wish I knew what I was doing...
1970 C10 Stepside
1972 C20 Flatbed
Old 04-08-2011, 07:48 PM   #18
cableguy0
More than likely the valve adjustment. IM assuming its an inline 6. You need to bring the engine to #1 tdc. Remove the #1 plug and rotate the engine until you feel air pushing out of the spark plug hole. After that bring the mark on the balancer around to meet the 0 on the timing tab. Your now at #1tdc. WHen your at #1 tdc adjust intake valve 1,2,4 and exhaust 1,3,5 now turn the engine to #6 tdc adjust intake valve 3,5,6 and exhaust valve 2,4,6. To get to #6tdc just turn the engine one complete revolution from #1 tdc and line the timing mark up to 0 again.
Old 04-08-2011, 10:19 PM   #19
telly
telly's Avatar
I hate to admit it, but I simply had a connector to the ignition coil come loose. Once I reattached it the truck started right up.
Now I need to adjust the valves and reset the timing...another day another adventure.
Thanks again to everyone for your input and advice. It is much appreciated.
1970 C10 Stepside
1972 C20 Flatbed
