#1 | |
Short box measurement please
I am in the process of shortening my box but since my frame was only shortened in the middle I have to cut the front of the box only. I would like to keep the same dimensions over all as a regular short box. Thanks for your help.
76 Chevy Crew Cab Build 6.2 Diesel with a Banks Turbo Turbo350c NP205 Dana 44 Front 14 Bolt Posi Rear Quote:
BMW & ASE Master Certified
Re: Short box measurement please
im pretty sure from the wheel well to the tail light has a different length + a different taper... better off selling what you got and getting a short bed box..
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
I'm curious about these dimensions as well because I have an extended cab conversion truck and I'd like to know if the tonneau cover for a short bed will fit it or not.
If nobody gets you measurements before I get home I'll measure mine for you
#5 | |
Anyone?
14" comes off in the middle, 5-6" comes off the back end of the frame. My truck is up the road or I would get some numbers for yah.....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
#7 | |
Thanks b454rat here's the thing I had bought my frame and and all my 4x4 stuff from a fellow that was going to make a crew cab short flat bed and he cut the full amount in front of the rear wheels about 18" or 19" not sure the exact amount. So I am trying to get the box the same length as a factory box. I know the wheels won't be in the middle of the box but that"s ok with me.
I will have some measurements posted for your shortly.
Jeremy I have done so much, for so long, with so little, I can do anything with nothing! 1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.) 1986 GMC Suburban 3/4 ton 4x4 2014 GMC Sierra LTZ Z-71 Crew SWB |
66 7/8" wide by 78" long. Let me know if you need anything else.
#10 | |
Thanks that helps.
Please post your mods...short beds are hard to come by here in the rust - salt use belt.
So can you take the difference off of the front and make a shortbed? I realize there will be quite a bit of body work to make it look right.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 04-09-2011 at 01:20 PM. |
How is the shortening going ?
I'm about to do the same thing. |
#13 | |
Lets put it this way God gave much more patience than cash. I have some of the prep work done on the box but I need to run 220 power to my shop and get a welder and learn to weld. I know I will get it done some day, even if it takes small steps.
Hwy whats the inside length and width of a full size 80's stepside? Im in the process of planning my bed.
#15 | |
I'm lucky to have a friend with a fully equipped fab shop who gives me free run of the place. Keith |
