Old 04-08-2011, 11:18 PM   #1
ppbr2001
ppbr2001's Avatar
Crazy thought
Thinking of swapping the 305 for a 454 and putting a muncie 4 speed behind it. Has anybody ever replaced an automatic with a standard before? Wondering about a clutch pedal and linkage.
ppbr2001 is offline   Reply With Quote
Old 04-08-2011, 11:45 PM   #2
Altec
Getcha Pull
Altec's Avatar
Re: Crazy thought
Doing the swap right now. Here is a basic parts list.
1. Bell Housing (Either a mechanical Linkage, Or Hydraulic)
2. Flywheel (And the proper bolts, they are longer then flex plate bolts!)
3. Clutch Disc (Either a 11" or 12" will work, but you need the matching pressure plate)
4. Pressure Plate (And the mounting bolts)
5. Throwout Bearing
6. Pilot bushing (you can get either a bushing, or bearing. I prefer bushings)
7. Transmission (And the four bolts that attach it to the bell housing)
8. Crossmember (And the bushings the go between it and the transmission)
9. Transfer Case (If 4WD...)
10. Drive Shaft (Proper type, and length)
11. Shift Boot
12. Clutch fork dust boot
13. Dust Shield
Next you need to decide what kind of clutch you want. You can get two main types. Hydraulic, and mechanical linkage. To do the hydro swap, see the thread linked below where Larry does it.
http://67-72chevytrucks.com/vboard/s...d.php?t=431033
To do a mechanical linkage you need a few parts.
1. Pedal "tunnel"
2. Pedals (A small brake pedal, and a mechanical linkage clutch pedal)
3. Few random springs
4. Pedal-to-Bell Crank Rod
5. Dust boot for #4
6. Bell crank
7. Bell crank Bracket (It is riveted to the frame from the factory...)
8. Bell crank-to-clutch fork rod
Some of the parts can be had through here.
http://www.classicparts.com/Transmission/products/393/
http://www.classicparts.com/Clutch-Parts/products/433/
Picture of the bell crank.
http://i13.photobucket.com/albums/a2...e/IMG_0031.jpg
'81 K10 454/SM465
'86 S10 Blazer
'95 H-D Softail
'96 Integra
Altec is offline   Reply With Quote
Old 04-09-2011, 01:14 AM   #3
ajester
ajester's Avatar
Re: Crazy thought
I have done the swap, it went well, really like it over the auto. I just have issues with the mechanical linkage clearing headers, but I will tackle that when I put my 454 in.
Aaron
85 k10 4" lift 454 in the works
ajester is offline   Reply With Quote
Old 04-09-2011, 06:28 AM   #4
ppbr2001
ppbr2001's Avatar
Re: Crazy thought
Sweet! Think I'll go with the hydraulic clutch.
