Old 04-10-2011, 11:20 AM   #276
Hommer
Talking Re: No Limit '72 C-10
Originally Posted by M5- View Post
Rob
Now that you are closer to being done and tuned are you planning on offering a total C10 package for the DIY guys basically 1 stop shopping front to rear for all the parts maybe with some directions for the A arm mods as well as frame bracing. I have a 65 SB Stepside I want to make handle but I don't want to do the trial and error shopping system if you get my drift. I'd really like to just do the work and have somebody else who has a clue figure what works.
Thx M5
X2 can't wait to see!
Hommer is offline   Reply With Quote
Old 04-14-2011, 01:02 AM   #277
hotroddr
Any chance you could post up some more pictures of how you raised the crossmember into the frame?
1968 Firebird
1966 Suburban
hotroddr is offline   Reply With Quote
Old 04-14-2011, 10:51 PM   #278
michaelnolimit
Active Member
Let me see what I can do. Please be patient. I'll try to post some more pics Saturday or Sunday. Yes we will be offering some products. Separately or as a chassis package. Not sure when. Be patient. It will be soon.
michaelnolimit is offline   Reply With Quote
Old 04-15-2011, 03:42 PM   #279
Number98
Prestige Worldwide
Number98's Avatar
Man, just read through all of this and your truck came together really nice....and quick too
So did you guys decide not to use the mustang buckets after all?
Number98 is offline   Reply With Quote
Old 04-15-2011, 07:43 PM   #280
robnolimit
robnolimit's Avatar
Honestly, the mustang seats suck. for now, we have a recovered (mexican blanket) stock bench. But, it sucks too. We are going to a 60/40 split bench from a 88-98 chev p/u. Autocrossing in Del-Mar was fun, but sliding around on the seat, and slamming into the door isn't the fast way around. lol
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 04-17-2011, 03:51 PM   #281
Conundrum
Conundrum's Avatar
Finally found this thread!
Looks great so far, and I can't wait to see more!
74 GMC SWB Project "Sin-thia" Static Dropped 8"f/10"r
http://67-72chevytrucks.com/vboard/s...d.php?t=460030
97 GMC reg cab short bed, 4.3V6 / 5spd, daily driver
220,000 miles, all stock for now
Conundrum is offline   Reply With Quote
Old 05-04-2011, 03:45 PM   #282
robnolimit
robnolimit's Avatar
last night we went back out to Adams Motorsports park and ran some Time-Attack laps with the J.T. It was warm, and the track had some good rubber on it, so it was a good night. We haven't made any real big changes lately. 1. We gave it a good alignment before Del-Mar. 3/4* neg. camber, 7* pos. caster, and 1/8" toe out. It drives great, feels very stable at speed, and turns in very well with this set up. 2. We installed two toggle switches in the glove box. One interupts the VSS signal to the ECU, with the switch off, the ECU see's no speed signal, and doesnt try to shift the trans for us. The second switch is a seporate power input to lock up the torque converter. So, we can keep it in second gear, and the converter stays locked, so that the truck pulls off the corner better. The result, Mike Sullivan, a tech here, put down a 51.27 fast lap (previous fast lap for the truck was 53.53) Next project is to swap to air ride in the rear.
Old 05-04-2011, 03:52 PM   #283
67cheby
67cheby
67cheby's Avatar
i dont know alot about auto-crossing...but that sure looks like a respectable drop in time !!
67cheby is offline   Reply With Quote
Old 05-05-2011, 03:18 PM   #284
robnolimit
robnolimit's Avatar
Yeah, thats huge. I think the rear difference is in Mike getting used to driving it. The seat is really proving to be a P.O.S. looking for a 88-98 split 60/40 seat.
Old 05-05-2011, 03:28 PM   #285
thor
thor's Avatar
Couple of questions if ya don't mind...
1) Toe-in vs. toe-out. How does that affect entering and/or exiting a corner? Which is better? In what situations? When should you align for toe-in? When should you align for toe-out?
2) You installed toggle switches to control the 4L80e the way you want. Awesome! With the VSS signal disabled, do you shift the tranny just like if it had a manual valve body? Stock column shift or floor shifter? If so, this would give you the best of both worlds. Leave it on for cruising. Turn it off for spirited driving.
Thanks for your time! AND, I love this thread !!!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 05-06-2011, 12:56 PM   #286
69CST-V
69CST-V's Avatar
Subscribed......Thanks for all the information and details in the changes you're making. Good job.
Bryce
'69 SWB Fleet Still Under Construction
Company Trucks
69CST-V is offline   Reply With Quote
Old 05-06-2011, 03:54 PM   #287
robnolimit
robnolimit's Avatar
TOE - to start with, if you set the front wheels parallel, 0 toe, it will wander around the highway, and follow every groove and lane cut. No good. So, a slight amount of 'conflict' between the front wheels will keep them going straight ahead. Most cars/trucks alignment spec is toe'd 'in'. Remember that most people aren't very good drivers, and don't really pay attention. Toe in makes the car/truck a bit lazy, but easy to drive. Toe out makes them much more responsive, but can be twitchy. If you enjoy driving, try a little bit of toe out, maybe 1/8".
With the vss off, it will stay in the gear you set it in. I have a floor shift, but I don't shift at all on a short track. It is worth the 3 bucks for the swith.
Old 05-06-2011, 05:12 PM   #288
Hart_Rod
Hart_Rod's Avatar
Good info on the VSS Rob. Would you happen to know the pin number of these 2 wires so we can all try it? Also, I got the new panhard bracket installed and it fits great. Any idea when the sway bar kit will be ready? That's the last thing I need to finish my suspension, .
Hart_Rod is offline   Reply With Quote
Old 05-06-2011, 09:43 PM   #289
robnolimit
robnolimit's Avatar
Looks good, - the panhard should be level at ride hieght. I don't know if your truck is lifted in the picts or not, but take a look at putting the bar mount on top of the mount plate. That may make it closer to level. Sway bars due in 2 wks.
Old 05-06-2011, 10:03 PM   #290
Hart_Rod
Hart_Rod's Avatar
I replaced the 4" dropped springs with 6" dropped springs and that took care of the problem......
Old 05-07-2011, 05:07 PM   #291
Hart_Rod
Hart_Rod's Avatar
How's this?
Old 05-08-2011, 02:17 PM   #292
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by Hart_Rod View Post
How's this?
Better than before. Looks better too I would still look at flipping the mount to the topside. You want it parallel with the ground (or the axle tubes) at ride height, assuming you have room with the cast diff cover...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 05-09-2011, 03:31 PM   #293
thor
thor's Avatar
Thanks for the schooling on "toe." As for VSS off, I've heard of people having problems with trannies going into limp mode due to no VSS. Not true in your case tho? I'm guessing it's the way you wired it?
Old 06-13-2011, 05:12 PM   #294
aggie91
I'm just glad to be here!
aggie91's Avatar
I just found this thread...i will have to take the time to start at the begining...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 07-15-2011, 09:51 AM   #295
Greywolf200
Saw the first article in the series on JT in Street Trucks and am looking forward to future installments.
Jack Byrd
'70 Chev Custom SWB(new to me), 307CID(added Weiand Stealth, headers and Edelbrock Performer carb, up to 17 MPG now), 700R4
'76 Airstream Argosy MH(want a longer one), 454CID, TH400
Greywolf200 is offline   Reply With Quote
Old 07-21-2011, 07:32 PM   #296
effects66
effects66's Avatar
I am loving the truck. It has a great look!! What rims are those?? Look like Rockets or Billet Specialties?
effects66 is offline   Reply With Quote
Old 07-21-2011, 09:25 PM   #297
robnolimit
robnolimit's Avatar
they are Rocket's. good price, 18 x 9 all around, 275 40 18 BFG KDW tires.
Old 08-10-2011, 11:29 PM   #298
aggie91
aggie91's Avatar
Was finally able to read this whole thread. I had foot surgery this morning and was able to spend some time on here. I have seen the magazine articles and was hoping for the details in the frame mods.
Any pictures/layouts of the changes as mentioned earlier? Is JT going to be at the GG show in Dallas this fall?
Karl
The LST Challenge:
Old 08-11-2011, 02:08 AM   #299
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
Looking good. Do you have any finished shots of the exhaust routing from front to back. I like the looks of them exiting RIGHT behind the rears like that. By the way, congrats on the article in Classic Trucks (I think). Although you guys are no strangers to the shiny pages.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 08-11-2011, 06:01 PM   #300
68Stepbed
68Stepbed's Avatar
Wow! I missed alot since I haven't been able to check this thread much. Nice work, Rob and the No Limit crew. I think I'm gonna look into some of the products offered.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
1972 chevy, c-10, no limit engineering
