Old 04-10-2011, 10:34 PM   #1
trapperjack
trapperjack's Avatar
Quick bed swap question......
I know I've seen this on here, but haven't been able to find it searching, so....
Will a 70 or 71 metal floor bed bolt on in place of a wood floor 67 bed? It's a long bed, if that makes a difference. Was going with a flat bed, but a really good 70 has popped up around the corner from me, and it's cheap. If I can drop it on and tighten 8 bolts, I'm going that way. It's even the same color, and the side markers are shaved, so it'll match my 67.
Thanks ya'll.
1962 Chevy K10 factory 4x4 stepside longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=494632
1967 Chevy 3/4 ton 4x4 long bed (Henrietta) traded
1968 Chevy 1/2 ton panel wagon, V8 and powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=483345
1978 Ford F250, beater stepside
2008 Jeep Wrangler 4 Door
2010 Chevy 4x4 plain jane work truck
trapperjack is offline   Reply With Quote
Old 04-10-2011, 10:38 PM   #2
cpisani70@aol.com
cpisani70@aol.com's Avatar
Re: Quick bed swap question......
I think it will bolt right on if not modify whatever you have to that deal is too good to pass on
cpisani70@aol.com is offline   Reply With Quote
Old 04-11-2011, 01:35 PM   #3
trapperjack
Came in for lunch, and to see if anyone else wants to chime in. I can't pass it up if it will bolt on. I could be tagged and inspected in a couple of days. The flat bed is going to take some redneck engineering to make work. But 8 bolts and done is tough to beat.
Thanks.
Old 04-11-2011, 02:03 PM   #4
JORGIE95961
Thanks.
i think the only difference is the header panel is taller to accept the thicknes of the wood
JORGIE95961 is offline   Reply With Quote
Old 04-11-2011, 02:10 PM   #5
sameyrasmea72
sameyrasmea72's Avatar
As long as you had a wood floor fleet side or step side, it will mount right up. If you had some sort of flatt bed or aftermarket bed on there, then you might be missing some mounting brackets on the frame.
72 Cheyenne Super
80 Silverado Blazer 2wd
sameyrasmea72 is offline   Reply With Quote
Old 04-11-2011, 04:28 PM   #6
trapperjack
Thanks all. Really nice guy I'm getting the bed from. He's delivering it tonight. Hope the bolts from the wood bed will work on the steel floor.
