Old 04-11-2011, 09:19 PM   #1
05crewcab
05crewcab's Avatar
Embarrassed on the side of the road...
hi guys,
On my way home today my truck died on me. I was cruising along at 35mph and all of a sudden my tach drops to 0 and then silence. Get to the side of the road and crank crank crank, nothin. Dead.
What I have:
Gas in the carb
Cranks but no fire
All dash lights, signals, headlights, etc. work
All fuses look good
I checked the fusable link on the small black wire by the battery and it is broken (i may have broke it when pulling the connection apart)...what exactly does that control?
Otherwise, I think it is something in my dizzy (HEI) but don't know how exactly to check for spark.
Can you guys help me in the right direction on where to start troubleshooting?
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 04-11-2011, 09:24 PM   #2
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Re: Embarrassed on the side of the road...
HEI or points? Are you getting spark?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-11-2011, 09:27 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Could have been the control module in the dizzy. There should be a full 12 volts to the HEI (some people use the old points wire to hook it up but it's only 8 volts) and there are supposed to be two ground straps inside of the dizzy. One is a metal strap the other is a ground wire from the coil. Either one of these things could have fried the coil or the control module.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-11-2011, 09:31 PM   #4
71swb4x4
71swb4x4's Avatar
I agree, check that control module first. You can pull it out and take it to the parts store, or just buy one and swap it in and see. It never hurts to have a spare in the glove box, they tend to go with no warning.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-11-2011, 09:50 PM   #5
05crewcab
05crewcab's Avatar
Thanks for the quick replies guys. Anyone have a picture of this control module, and where it is located inside the dizzy?
What about that fusible link? what does that black wire control? the diagram I have shows it deads off at the bulkhead connector...
Thanks again
1971 C-20 350/350
Old 04-11-2011, 10:00 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Located under the rotor.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-11-2011, 11:36 PM   #7
Dads69C10
Dads69C10's Avatar
I had the same problem recently. Just a loose wire to the Hei
1969 C10 stepside
1973 Cheyenne Blazer
Dads69C10 is offline   Reply With Quote
Old 04-11-2011, 11:39 PM   #8
70C10Toejam
Hellasick
70C10Toejam's Avatar
Are you talking about this connection?
If so, (from another thread) it supplies one of the sources for the alternator gauge. There is another one on the drivers side where the alt's output connects to the power junction.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 04-11-2011, 11:59 PM   #9
2002on22s
My first go to would be the dizzy as well - But if that checks out I'd look at the timing chain
2002on22s is offline   Reply With Quote
Old 04-12-2011, 12:06 AM   #10
05crewcab
05crewcab's Avatar
Yep, that is the one...i bet that (well both) have been blown for some time...no wonder my alt guage is always at 12 o'clock
I tore down the dizzy and got to the control module. It's a GM part so i assume it's original to the dizzy. I also had fine brown dust on the advance weights (not sure how to tell those are bad) and the contact on the rotor was corroded...looks like a new cap and rotor are in order as well.
1971 C-20 350/350
Old 04-12-2011, 12:20 AM   #11
wwotr
wwotr's Avatar
Originally Posted by 67chevyredneck View Post
could have been the control module in the dizzy. There should be a full 12 volts to the hei (some people use the old points wire to hook it up but it's only 8 volts) and there are supposed to be two ground straps inside of the dizzy. One is a metal strap the other is a ground wire from the coil. Either one of these things could have fried the coil or the control module.
x2
Hello members...
I'd like you to know that I sold,
my 72 GMC (Ratikle),
back in November of 2011.
I don't visit the site much anymore,
but please feel free,
to drop me a private message.
RIP...."RATIKLE"
wwotr is offline   Reply With Quote
Old 04-12-2011, 07:00 AM   #12
Although I'm a fan of the HEI,that's the problem with electronic. It'll just quit and you got nothing. Never had points leave me dead without warning. Be sure to check the two wires from the base to the cap for breaks in the insulation. I mean flex them and look real hard. I replaced two modules within two weeks because of those little buggers.
Old 04-13-2011, 12:07 AM   #13
05crewcab
05crewcab's Avatar
Haven't had a chance to check further whether it is the dizzy or if the problem is pre-dizzy, but stopped at O'Reilly's over lunch today and picked up a new cap and rotor and control module, and admittedly, a multi-meter (shoulda had that a LONG time ago)... anyway, the total was $105 bucks...on my way out the door, I see a MSD Streetfire HEI for $159. Question becomes, if it is the module that is bad, why wouldn't I just buy a new MSD dizzy? Who is running them? What is the report?
1971 C-20 350/350
Old 04-13-2011, 08:31 AM   #14
mrein3
mrein3's Avatar
You said "Cranks but no fire"
Do you mean it turns over but doesn't try to start? Some of the old schoolers I know say "no fire" when they have no spark.
Did you confirm whether or not you have spark?
Did you confirm whether or not you have fuel?
These old, not computer controlled engines are pretty simple. Verify that you have spark. There are timing lights with an inductance coil you can clamp around a spark plug wire and see if the light blinks while cranking. There are "clip on" spark plug looking device you can put in the business end of a spark plug wire, clamp to a ground on the truck, and turn it over. Have your wife/girlfriend hold the end of a spark plug wire while leaning on the truck while you turn it over [JUST KIDDING]. Make sure you have spark.
If you have spark, verify that you have fuel. A good way to do that is pour a touch of gas down the carb and turn it over. If it runs until that fuel is gone you probably have fuel delivery issues (again assuming you have spark).
If you have fuel and you have spark but it doesn't run, you may have skipped a tooth on the timing chain. I jumped a tooth once on a small block 350. I started it up and hopped out to brush the snow off on the way to school. In the middle of snow removal the car simply stopped running. Crank crank crank nothing. It turned out the original, plastic coated timing chain gear wore off enough plastic and went and got itself out of time. It sounds like that may be what happened to your 350.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-15-2011, 11:35 PM   #15
05crewcab
05crewcab's Avatar
She's alive!!!
I tested power to the dizzy and it was at 12v so I then knew it was the control module. I inspected the harness from the terminals to the control module and it appears to be in good shape, so I just replaced the module. I pulled the dizzy to do it, but I could have done it while in the truck which is what I will do next time (knock on wood). Got it all back together and she roared to life on the first crank
Here's what I am into it for:
MSD Cap and Rotor - $30
Accel Ignition Control Module - $50
Multimeter - $15
Question for you guys, I didnt put any dielectric grease on any of it, but there was evidence of that grease on the old cap and rotor...thoughts?
Thanks for all the help!
1971 C-20 350/350
Old 04-15-2011, 11:47 PM   #16
Myself
You need that dielectric grease on the bottom side of the module. It acts as a heat sink to cool the module. It won't last long without it.
Myself is offline   Reply With Quote
Old 04-15-2011, 11:56 PM   #17
05crewcab
05crewcab's Avatar
Failed to mention... yes, I put it there because the new one came with a little pouch of it, but nowhere else.
1971 C-20 350/350
Old 04-16-2011, 08:35 AM   #18
67ChevyRedneck
Sweet!
Hey, I was right for once
Jesse James
Project "On a Dime"
Old 04-16-2011, 09:26 AM   #19
Boog
laying low
Boog's Avatar
attaboy
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 04-16-2011, 09:55 AM   #20
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Next time you are in the junkyard, grab another GM module. They are a million times better than the cheap parts store pieces, and still better than the MSD/Accell pieces.
Old 04-16-2011, 10:13 AM   #21
pat 70/71
pat 70/71's Avatar
I took my sons to a track day (motocross) and on the way home our truck just stopped (82 sbd) middle of nowhere, I knew my problem was the control module because we had plenty of fuel/good battery. I had no real tools with me only a screw driver and a metric adjustable cressent wrench lol, anyway it was getting dark and the boys wanted to eat so I opened our ice chest took out a piece of ice and set it on the module (sounds like bs but it worked) we did this every 20 minutes or so all the way home. Now I have a spare module in the glove box on all our trucks. cheers, Pat
pat 70/71 is offline   Reply With Quote
Old 04-16-2011, 01:27 PM   #22
Indyuke
Had the same thing happen to me. When it first happened I had just gone through a massive puddle and splashed water everywhere, so I thought I'd watered down some connection somewhere. 20 mins later I was back on the road, but it kept happening over the next couple of days. Bought a new HEI module and it hasn't happened since.
Indyuke is offline   Reply With Quote
Old 04-16-2011, 06:43 PM   #23
lil hoodlum
lil hoodlum's Avatar
I've never had mine go out on me but I allways have a spare or two in my glove box.
Keith
lil hoodlum is offline   Reply With Quote
Old 04-16-2011, 11:26 PM   #24
05crewcab
05crewcab's Avatar
Now we have trouble... I started my truck and let it run for a little while today for the first time since I pulled the dizzy and changed the module. I have NO oil pressure!!!!
I let it run and it started knocking bad in the top end and I checked the oil pressure guage...nothing.
What did I do wrong?? I just pulled the dizzy and re-installed it...is there a piece from the oil pump to the diz that came loose or needs to be aligned? Did I not put my diz in far enough?? I'm stumped and immobile. Thoughts?? Thanks guys.
1971 C-20 350/350
Old 04-17-2011, 12:30 AM   #25
splehigh
splehigh's Avatar
As long as your distributor is down all the way against the intake it should be seated in the oil pump shaft. Sometimes you have to put a screw driver down the hole and turn it to line up with the distributor.
splehigh is offline   Reply With Quote
