Old 04-11-2011, 10:07 PM   #1
ol'blu72
Body Flex
Ive been hearing a very annoying squeak and I pinpointed the cause. My body is flexing causing one of the rivets in the door jamb to contact the striker plate. It is wearing a little groove in the striker. What concerns me is the body flex, if i bounce in my truck I can see the flex by watching the door gap. The movement is maybe a quarter inch. Should I be concerned?? My fear is I will have to replace my rockers sooner rather than later.
Brad
72 Blazer CST 350/350/205
ol'blu72 is offline   Reply With Quote
Old 04-11-2011, 10:21 PM   #2
71swb4x4
71swb4x4's Avatar
Re: Body Flex
How are the rocker boxes? How about the bushings between the frame and the body mounts?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-12-2011, 08:26 AM   #3
ol'blu72
Re: Body Flex
My bushing are pretty shot I was going to try that first hopefully that will fix it. I dont want to jump into the rockers quite yet, after all its summertime and I want to drive!!
I do see some slight rot beginning on the rockers (starting to bubble paint), and from what ive heard that means its not going to be any better inside.
Does anyobody know how much flex is normal??
Brad
Old 04-12-2011, 09:39 AM   #4
turp mcspray
turp mcspray's Avatar
Re: Body Flex
A lot of the inner structure that you can't see (lower hinge pillars behind the rocker, lower kick panel area below the floor level, and front floor supports) are more than likely rusted away. This will drastically weaken firewall/cowl strength.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 04-12-2011, 10:01 AM   #5
Burt4x4
Burt4x4's Avatar
Re: Body Flex
Are your rocker boxes still inplace?
Take pics
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-12-2011, 02:06 PM   #6
ol'blu72
Re: Body Flex
See this is exactly what I didnt want to hear
Yes my rockers boxes are there, however I have the rear covers off them, but I dont think that would affect it that much.
I will shoot some Pics when I get off work. I will also check how bad the body mount rubber is in that area.
Brad
Old 04-12-2011, 05:14 PM   #7
ol'blu72
Re: Body Flex
Here are some pictures of the drivers side rocker, this is the bad side. So tell it to me straight is it gonna be major surgery or can I nurse it along for a while?[ATTACH][ATTACH][ATTACH]Name:  DSC_0160.jpg
Size:  37.6 KB[/ATTACH][/ATTACH][/ATTACH]
Here is the body mount, looks like its had better days.
Brad
Old 04-12-2011, 05:34 PM   #8
Burt4x4
Burt4x4's Avatar
Re: Body Flex
That's not bad at all! hahaha
I would put that rockerbox bact togeather and then buy a body mount kit from EnergySuspension and replace that old rubber. I would leave the rockers..about 10yrs from now then replace them
Old 04-12-2011, 05:40 PM   #9
1949gmc
Re: Body Flex
x2.... more than likely, the bottom of the A pillar and the front body mount are rusted some, but by the looks of it, not enough to cause the kind of flex you're talking about. That's a clean truck, as far as first gen K5's go. Change the body bushings and go from there.
1949gmc is offline   Reply With Quote
Old 04-12-2011, 05:43 PM   #10
ol'blu72
Re: Body Flex
Man you guys are my new best friends!! I should buy you a beer!
Brad
Old 04-12-2011, 05:50 PM   #11
ol'blu72
Re: Body Flex
Ok, so now what are the pros and cons of the urethane mounts. I'm trying to keep her as stock as I can so right now I'm leaning towards rubber.
Brad
Old 04-12-2011, 06:36 PM   #12
70cst
70cst's Avatar
Re: Body Flex
I'll get you their addresses
Just kidding
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-12-2011, 08:09 PM   #13
turp mcspray
Re: Body Flex
I am restoring a 72 2wd, for a customer. His rocker boxes are excellent. But due to the rust I described above, I could move the top of the windshield frame, back and forth by SEVERAL inches! I think some blazers had rusty floor supports and lower hinge pillars installed at the factory. LOL! As others have suggested, I would also start with those rotten body bushings. Since the rear rocker box covers are off, look inside them with a flashlight, to check your floor supports.
Turp Mcspray
Old 04-12-2011, 09:47 PM   #14
SeventyOne
Re: Body Flex
I am going polyurethane to prevent the rubber ones from squashing out like yours. I figure the added rigidity and longevity can't hurt.
SeventyOne is offline   Reply With Quote
Old 04-13-2011, 10:52 AM   #15
Burt4x4
Burt4x4's Avatar
Re: Body Flex
I swtched to Poly about 17yrs ago and I have never had to mess with the mounts eversence
I learned two things about Poly.
1. Black vs. Red ~ Choose Black- Black is impregnated with polygraphite too prevent "poly squeek". Red is just for looks
2. Do not overtighten or squeese poly. It will bind and not flex. I got the mounts nice and snugg right before the poly starts too bulge. If you overtightn it just too see the mount bulge then back off the nut until it relaxes. Then I used nylon lock nuts to keep things inplace.
I remember it changing the way my rig road bigtime! Made everything feel so much more solid...well not too mention only 5 out of the 12 mounts were actually holding the body too the frame too begain with!!
Some like rubber too use in a reto project but I think poly out performs rubber in both time and function...
Anyway I need more coffee
