Old 04-12-2011, 02:19 AM   #1
Andyboy
Andyboy's Avatar
Transmission indicator
Can someone tell me what trany this indicator is used for? Might not be able to see it but it says ( I4 I3 I2 R).
Andyboy is offline   Reply With Quote
Old 04-12-2011, 08:07 AM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Transmission indicator
Do you have a close up of it?
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 04-12-2011, 08:24 AM   #3
Str8axle
Str8axle's Avatar
4 spd Hydra-Matic is what that sounds like to me.
Ray
All my life, I've been told I'm a "Bad Influence"
Str8axle is offline   Reply With Quote
Old 04-12-2011, 02:55 PM   #4
Surfdaddy
Surfdaddy's Avatar
Yes it's a Hydramatic selector 4spd auto trans. I found that reverse turns into park when the engine is turned off. And you have to have it in netural when starting.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 04-12-2011, 03:19 PM   #5
jchav62
1962 C-10
jchav62's Avatar
Pretty rare I would say! Seems like it says 1-2, 1-3 and 1-4 as opposed to "I".
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-12-2011, 09:38 PM   #6
Str8axle
Str8axle's Avatar
How do you guys like that trans? I have a B&M Hydro for my 55 Chevy straight axle car, but haven't driven it yet (still under construction).
Ray
Old 04-12-2011, 09:55 PM   #7
Rich 5150 69
Rich 5150 69's Avatar
I`m still looking for a adapter first Ray....
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-13-2011, 08:44 AM   #8
Str8axle
Str8axle's Avatar
Rich? Hey man! Didn't realize that was you!!
Ray
Old 04-13-2011, 09:04 AM   #9
jbgroby
jbgroby's Avatar
Andy,
The way the trans. shifts is when you are driving normally at all speeds, you put the indicator in the 1-4 position (trans will work through all gears). If under load (about a 1/4 ton), you’d use a lower gear 1-3 (shifts from 1st. -3rd. gear only). If under (full load 1/2 ton) you'd used 1-2. When you park, you place the trans. in natural kill the engine and then shift down to R, a cam will drop into the teeth of the trans and serve as the parking cam.
When I first got my truck it took me a bit to get used to and because the trans was adjusted wrong, it would bark the tires in 2nd. Gear. Scarred the hell out of me and (others I'm sure) at a stop light a few times.
Jake
jbgroby is offline   Reply With Quote
Old 04-13-2011, 10:22 AM   #10
Surfdaddy
Surfdaddy's Avatar
Since mine has been sitting for so long I'm finding that it shifts very quickly, from 1st to 4th in about 100 feet, then very hard when down shifting . I'm trying to find a service kit for it now since the output shaft seal is starting to leak.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 04-13-2011, 05:21 PM   #11
61_FL_Apache
Who Me?
Must be a GMC thing. On my 61 it says P R N 2 1
Steve
2001 Blazer 4D 2WD
Old 04-13-2011, 07:17 PM   #12
Surfdaddy
Surfdaddy's Avatar
GMC used the Hydramatic in 61 and Chevy used a powerglide. I don't see in my service book if they offered the powerglide in 61. They may have but I can't find the info on it.
Past projects:
1966 Caprice 2dr
1970 VW Squareback
Old 04-13-2011, 07:33 PM   #13
jbgroby
jbgroby's Avatar
Try this company Fatsco Transmission, they have all the old stuff.
http://www.fatsco.com/index.htm
Old 04-13-2011, 08:21 PM   #14
Andyboy
Andyboy's Avatar
Thanks guys, a lot of helpful stuff. Pick up truck tomorrow.
