Old 03-28-2002, 12:34 PM   #1
Mike_G
Post Gauge Problems
I have two problems with my gauges. First of all the gas gauge only works when it feels like it. It will work perfectly for two or three days, but then it will just fall to the right and lay there. There doesn't seem to be any connection between when it decides to work and when it doesn't. Second, my gauges don't light up when I turn on the headlights. The headlights work and the dimmer switch and the gauges themselves work (with the exception of the finicky gas gauge). I haven't pulled the gauges yet, but what should I look for first as a cause and could the gas gauge and the lights be related?
-Mike
Still looking for that perfect project. Anyone?
Mike_G is offline   Reply With Quote
Old 03-28-2002, 01:21 PM   #2
TC70C10
TC70C10's Avatar
Post
Sounds like a ground problem to me. I've seen alot of dash's that are rusted. Pull the dash and check the area where the back panel mates to the front panel.
Also, I had to run a ground wire from the back of my gas gauge to get it to work correctly. The dash lights could be the wiring harness mates to the circuit card on the back of the dash.
1981 K5 Blazer 305, 4spd, 4x4, 4" Lift, custom bumpers, Warn 9.5 Ti Winch
1995 T10 Blazer 4.3L 4x4 (Son's)
2004 GMC Envoy 4.2L 2WD
2005 GMC Sierra Crew Cab Z71 4x4 5.3L
240 Fun Finder Travel Trailer
Harvest, AL 35749
TC70C10 is offline   Reply With Quote
Old 03-28-2002, 01:22 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Thumbs up
Hey Mike,
Start checking the the push-in bulbs one by one. I need to do the same thing this weekend.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
