Old 04-13-2011, 01:02 PM   #1
ubtripn
ubtripn's Avatar
need help fast - storm coming and I am working outside
Can I take the upper and lower ball joints off without the spring expanding? I am doing both plus the outer ti rod ends, what order should I go, thanks!!!!
ubtripn is offline   Reply With Quote
Old 04-13-2011, 01:06 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: need help fast - storm coming and I am working outside
yep you can fill in the4 details
jack stand uinder truck
floor jack under A arm
pull wheel
loosen both upper and lower B nuts
BFH on the outside of the sindle to pop ball joints loose
remove B nuts
remove shock bolt
lower jack slowly until spring is unloaded
remove ball joints ( your going to need a press availble @ parts stores to borrow)
new ball joints
B Nuts back on
grease
then do tie rod
Hottrucks is offline   Reply With Quote
Old 04-13-2011, 01:07 PM   #3
Hottrucks
Hottrucks's Avatar
pm me a phone if you need help I'll walk you though it
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 04-13-2011, 01:13 PM   #4
ubtripn
ubtripn's Avatar
you are awesome, thank you
Old 04-13-2011, 01:15 PM   #5
ubtripn
ubtripn's Avatar
I think that did it, I may pm you still if I hit a road block but your instructions are great, thanks!
