04-14-2011, 02:57 PM | #1 |
Help with shocks...
What is the quality level of the shock brands out there? I'm assuming KYB near the top, monroe on the bottom. Where does doetsch tech, belltech,fit in? Any others?
Will the shock limit how low my vehicle can go when i air out my bag? (will it prevent me from bottoming out when i air out?) I know when you put a 3" drop spring, you've dropped your truck 3 inches. When you replace the spring with a bag, how much drop do you now have...
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 04-14-2011 at 03:09 PM. |
04-14-2011, 04:21 PM | #2 | |
Re: Help with shocks...
I can't answer your first question because I like to use stock replacement shocks & make my mounts to work w/them (or choose a similar vehicle w/a 'better' length). The other stuff is answered in red....
04-15-2011, 03:18 PM | #3 |
for the rear.....i have a bag, bolt-in notch and the shock relocator brackets. Do i buy just stock length shocks?
***just noticed i hit the 1000 post mark!!****
1992 Gmc 2wd 1972 Chevy Blazer 2wd Last edited by 72gmcshorty; 04-15-2011 at 03:19 PM. |
04-15-2011, 03:48 PM | #4 |
A guy with a truck
They will work if you are running a 2" block and a button bumpstop, or a 1.5" block and a tall bumpstop(for 15" wheels). Otherwise, the shocks will be too long.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
05-02-2011, 06:29 PM | #5 |
ok, i measured my rear aired out and came up with 11 1/4" center to center. I don't have a body or wheels on my frame so i'm not sure what my aired up height would be. Anyone have that measurement handy. I have bag and CPP notch.
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-02-2011, 06:47 PM | #6 |
Research what the air bag mfr recommends for ride height on your particular bags. Most dbl convoluted bags are around 2.8 - 3" @ full compression & between 5.5 - 6.5" @ recommended ride heights (sleeve type bags are slightly longer).
05-02-2011, 08:19 PM | #7 |
so i should be ok to assume my aired up height to be around 17 1/4" (i have the double convoluted bags). I need to find a shock that will cover 11 1/4"- 17 1/4". Correct?
05-02-2011, 09:44 PM | #8 | |
Sounds about right. But to clarify.... the 11.25'' + 3" = ride height (bag @ 6.5") so 14.25". Now figure in allowable extension of 2-3" & that puts you in the ball park of 17.25" max length.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-02-2011 at 09:48 PM. |
05-02-2011, 10:25 PM | #9 |
A guy with a truck
Easy way to figure out what you need online:
Go to the Monroe website - http://www.monroe.com/ - and figure out what your stock shocks are. Once you have this info, use the following guide to determine the mounting style of your stock shocks. Then, you should be able to find a shock that meets your mounting needs with your required lengths. http://www.monroe.com/assets/downloa...engthSheet.pdf Also a good idea to cross-reference your chosen shock's application to make sure the valving will be similar to your truck's. Happy hunting!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy Last edited by gringoloco; 05-02-2011 at 11:09 PM. Reason: FAT FINGERS! |
05-02-2011, 10:33 PM | #10 | |
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-02-2011 at 10:33 PM. |
