Old 04-14-2011, 04:09 PM   #1
jessewebb
jessewebb's Avatar
What kind of Aftermarket Tach???
Hello, I'm wanting to put an aftermarket tach in my dash the cluster. I found the thread giving great instruction on how to do it. My question is what kind of tach does it take to work without messing up the wiring sheet on the back of the cluster. I have a Sun Tach, it's to long or deep to install. It has to be a thin tach....but what brand and where can I get one???
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 04-14-2011, 04:26 PM   #2
Non_Sequitor
Re: What kind of Aftermarket Tach???
Are you talking about using the factory circuit sheet on the original gauge cluster to power the tach? I'm not sure why you would want to. Hooking up a tach is crazy easy. The tach reference signal goes to the negative terminal of the coil, the power lead goes to power source that is key-on, and the light hooks into your gauge light's circuit. The ground is obvious.
Non_Sequitor is offline   Reply With Quote
Old 04-14-2011, 04:32 PM   #3
stich626
where you putting it, the center hole..
if you're keeping the stock gauges most aftermarket tachs don't fit with use of the circuit wire (they are to deep)
but a 3rd gen f body tach (t/a,camaro,etc) will fit with a little work.
or mount the sun tach infront of the center hole
stich626 is offline   Reply With Quote
Old 04-14-2011, 04:34 PM   #4
Non_Sequitor
I guess I should have read the original post better. Sorry!
Old 04-14-2011, 04:54 PM   #5
doctrouble
doctrouble's Avatar
That is awesome. thank you. that is the most simplest I've seen that explained.
"Feel it's not a bonfire unless they can see it from space?" ~ Capt. Morgan
1970 Cst - 20 402
1984 Chevy C30 6.2L Diesel crew cab Dualie
doctrouble is offline   Reply With Quote
Old 04-14-2011, 05:02 PM   #6
jessewebb
jessewebb's Avatar
I want to put it in the center hole in the bezel,cluster... I found the thread on how to do it. Just need to know what kind,type of tach and where to find one. Thanks
Pete
04 325i lady's ride
Old 04-14-2011, 05:08 PM   #7
Non_Sequitor
Glad that my post helped someone! I just wish I had read the thread starters original post better so that I would have understood more of what he was asking.
Old 04-14-2011, 09:23 PM   #8
jessewebb
jessewebb's Avatar
ttt help me out here
Pete
04 325i lady's ride
Old 04-14-2011, 09:44 PM   #9
hayhauler71
hayhauler71's Avatar
I have a sun super tach 2 in my cluster but you have to cut the plastic part of the cluster and the tin part and the tach will slip in
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 04-14-2011, 10:01 PM   #10
jessewebb
jessewebb's Avatar
Thanks, for the info
Pete
04 325i lady's ride
Old 04-15-2011, 12:14 AM   #11
slikside
slikside's Avatar
Brothers trucks has the stock versions. They will fit in your stock cluster. The tach alone is $74.00 and the conversion kit (if you never had a tach installed) is 197.00. Just look under Interior, then dash components.
slikside is offline   Reply With Quote
