Old 04-14-2011, 07:26 PM   #1
Big Fenders
Master cylinder Firewall Hole
I've got a project Suburban that I have to make a master cylinder plate to cover the two holes in the firewall. This is a 1960 GMC. I do need to bore a hole for the brake master but since this sub is about 250 miles away from me I need to know the size hole to bore in the 1/4 inch plate...easier to do here in Tucson than there. Thanks Bob
Big Fenders is offline   Reply With Quote
Old 04-14-2011, 08:19 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Master cylinder Firewall Hole
Contact CaptainFab- I would think he could assist.
DPowers is offline   Reply With Quote
Old 04-14-2011, 08:37 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
Can’t confirm the hole diameter in the firewall, but I can confirm the hole in the plate sold by Master Power Brakes. It is 1 - 13/16” as shown in the attached photos. I ran this plate on my truck for a few years when I ran a Turbo 350 in my 1960 GMC. Eventually I went back to a manual 4 speed and fabricated a larger custom plate to accommodate the clutch master cylinder. If you want to save some effort you can have the plate for the cost of the shipping, or I can post a tracing of plate with dimensions if that’s helpful. If you’re interested shoot me a PM.
Old 04-14-2011, 10:01 PM   #4
jbgroby
jbgroby's Avatar
This is the plate from Capt. Fab.
It be pretty,arrrrrg (Pirate talk for Capt. Fab)
jbgroby is offline   Reply With Quote
Old 04-15-2011, 01:51 AM   #5
Captainfab
60-66 Nut
Thanks for the plug guys
The center hole in the plates that I make is 2-1/16". This is close in size to the hole in the firewall.
Old 04-15-2011, 05:19 PM   #6
53lowdown
Junior Member
53lowdown's Avatar
Sorry to hijack - but why does the Power Booster have to be tilted up like that on these trucks? Is it a clearance problem with the engine or manifolds? The manual master cylinders sit square with the firewall so it can't be a brake rod alignment issue.
_______________________________________
62 SWB BBW (under construction)
86 Vette Convertible
53lowdown is offline   Reply With Quote
Old 04-16-2011, 12:20 AM   #7
Captainfab
60-66 Nut
You know, I don't know of a reason for it other than keeping the master cylinder level, as some stock trucks were higher in the rear. But then if you look at the '67-'72 power brake setups, the master is tilted towards the front. Now the trucks starting in 1988, have the booster bolted directly to the firewall which positions the master basically cylinder level.
I designed my power brake booster brackets with a slight angle upwards simply because it just looks right to me.
