Old 04-15-2011, 12:56 PM   #1
bobs86silv
bobs86silv's Avatar
Will I regret stripping my truck down?
Just at the point where I am considering stripping un needed weight from my truck. It is all original so things like the un functional heater and air conditioner parts. Heavy bench seat. Where do I start. Where do I stop. Am I going to regret tearing up my truck later? Just want to go faster and know I could get it with less weight. thanks, Robert
86 Silverado SWB 350/350/3.08 9.7-1 Forged pistons Eagle Rods Eagle Crank Zero Deck Balanced Blueprinted 180cc DART Heads Roller Rockers RPM Intake Demon Carb Flowtech Headers 400HP/400TQ
bobs86silv is offline   Reply With Quote
Old 04-15-2011, 01:11 PM   #2
Your41Plague12
Your41Plague12's Avatar
Re: Will I regret stripping my truck down?
Unless you're drag racing for a living or something, I'd leave it original interior wise. I'd just build a motor/transmission and re-gear it if necessary to make it faster. It's only original once. Is it in your budget to buy a cheap one to make fast? It would be nice to have an original one and a quick one, in my opinion.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 04-15-2011, 01:19 PM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Will I regret stripping my truck down? Yes, you will. Unless its a track only truck, the weight saving vs. creature comforts is not worth it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-15-2011, 01:29 PM   #4
bnb0221
x2
bnb0221 is offline   Reply With Quote
Old 04-15-2011, 01:31 PM   #5
sumran
sumran's Avatar
If you are at the point that you are shedding a few pounds to gain speed you are getting serious. It would take many pounds to gain very little speed. If you are racing at that level the truck probably won't be a street truck. Find a shell that you can strip down and tow it to the track with your nice original driver. And when you are towing it around, don't be surprised if it is the original truck that gets most of the attention.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 04-15-2011, 01:38 PM   #6
babyJay
Arrived on a Pale Horse
babyJay's Avatar
time is money and money is time. The time will drastically outweigh the benefit. Do you have a lot of money to replace all the steel with aluminum? Your gas mileage improvement will not be noticeable either.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 04-15-2011, 02:00 PM   #7
Pyrotechnic
Pyrotechnic's Avatar
It's just not a good move. Make sure you are running light weight wheels, that's a place where you can save a lot of weight. At the track you can run pizza cutters up front to save even more. An aluminum or carbon fiber drive shaft can also help a lot too. Run a light weight gel battery at the track. They have some that are tiny, very lightweight, but pack enough punch to crank the motor over.
Remember, the general estimation is that every 100 pounds is a tenth of a second. You're going to have to remove a lot of weight to make a big difference. It's much easier to work on your engine to get the faster ET's.
EDIT: I just saw you have 3.08 gears. You have a lot to gain by switching to a 3.42 or 3.73. That's really where you need to start if you are concerned with your 1/4 mile time.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 04-15-2011, 02:10 PM   #8
swb85
On a budget like Fred Sanford
swb85's Avatar
I'm a big drag racer too......if it sees any street time leave it alone. Race cars/trucks are awesome, rowdy & fast.....but not very much fun to drive around in for very long. If you're itching to go faster, it's time to put a motor together that can handle nitrous or boost. Then when it's time to go even faster, all ya gotta do is crank up the boost or up the nitrous shot.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 04-15-2011, 02:16 PM   #9
fun in dirt
fun in dirt's Avatar
Originally Posted by Pyrotechnic View Post
Remember, the general estimation is that every 100 pounds is a tenth of a second...You have a lot to gain by switching to a 3.42 or 3.73.
Excellent points
And rememnber too 10 lbs of unsprung weight = a tenth!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432
'85 K30 "Big Nassy"
[B]'85 C10 [B] "Corpse"
'01 2500 Suburban ...party wagon & tow truck
'06 Silverado SS...DD
'06 C1500 WT...DD
'07 Classic C1500 WT...DD
Built & sold cause can't keep 'em all:
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is offline   Reply With Quote
Old 04-15-2011, 02:28 PM   #10
jitteryguy
GoatLube Experss
jitteryguy's Avatar
are we talk'n drag strip fast or street fast, it's a waste of time and money to build a fast street only car/truck. if were talk'n drag strip, leave this truck alone and find an old S10. cheap, small block will fall right in with very minor mods,somewhat light , and fun to drive when done .
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 04-15-2011, 11:03 PM   #11
DBLSPRT68
DBLSPRT68's Avatar
Yes you will. Don't do it. Build another lighter, faster truck........
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD
DBLSPRT68 is offline   Reply With Quote
Old 04-15-2011, 11:20 PM   #12
trixter99
I have no time for this
trixter99's Avatar
Sell your small block and build a big block and forget about stripping your truck.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 04-17-2011, 12:38 PM   #13
bobs86silv
bobs86silv's Avatar
Wow thanks for all the great input. Its just that I drove a buddys car the other day that has a mostly stock motor but is stripped down to like 2500 pounds, about a ton less than my truck. Needless to say it would smoke my snorting beast. There are many things I will be doing to my truck, especially gears, (about a grand for posi 3.73 setup and swap) Just was thinking about things I can do for free now. Just hard to think I would ever spend the money to get a new compressor and hook my A/C back up. And I put a heater core in 4 years ago. It started leaking so I bypassed it, really really dont see me going back into that dash to fix it. I only drive the truck on super nice days, so its just a toy anyway.
But thanks for the push for originality!!
Robert
