Old 07-19-2003, 02:48 PM   #1
GM72K10
Next!
GM72K10's Avatar
BBC in 72 4X4 motor mount ?s
Ok
To make a long story short, last year I got free, yes free a 72 GMC K2500 4x4 454 auto TH400, 3:73 gears, but MINUS the engine. As if I needed another one but free is real hard to say no at. The engine was in it when I first looked at, so I know this set up did work. The truck was inspected and running. The cab has gone to old Rusty C10 (needed a lot of work), bought a 72 C20 with a 402 Th400, low mileage, fixed that cab, have put the 402 in the frame with new motor mounts, am ready to put cab back on. QUESTION! Exhaust manifold hits frame, just barely, on driver's side. Don't have the motor mount pads from the previous engine, just bought new ones from NAPA, what needs to be done to make manifolds clear frame? By the way, this truck has original NP205, and every thing is moved forward so there is more clearance between firewall and back of engine already.
Thanks in advance
GM
86 K30 CUCV M1028A1
86 K30 CUCV M1028a2 dually
86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump
More square bodies and CUCVs than I care to admit to
2020 Silverado K3500HD Work truck
GM72K10 is offline   Reply With Quote
Old 07-19-2003, 04:47 PM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
When I put the 427 in mine I had to trim the frame a little bit with a grinder but, on mine, it was the passenger side that needed clearancing.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 07-19-2003, 06:20 PM   #3
GM72K10
Next!
GM72K10's Avatar
Frame already is trimmed on passenger side, so maybe I just need to do the same for driver's side. Thanks
GM
86 K30 CUCV M1028A1
Old 07-19-2003, 08:41 PM   #4
kwmech
Long ago when I did a big block in my 71, I used some factory triangle shaped spacers between the mount and the block. If I remember they were about 1/4'' thick. That did the trick for me back then.
