Old 04-17-2011, 05:33 PM   #1
1425956
1425956's Avatar
Trans leak from dust shield. Brand new front seal.
Well, the title says it all. This truck sat for 9 years and I have had to replace a bunch of seals and gaskets. I pulled the trans about 3 weeks ago to change the front seal on the trans due to a leak.
Got everything bolted back up and I still have a trans leak. If anything, the leak may be a little worse. It is dripping from the small hole in the bottom of the dust shield. The oil pan appears to be very dry. I can't get the dust shield off without removing or lowering the exhaust.
It is driving me crazy and I am having to park in the road so I don't get tranny fluid on the driveway. I am afraid someone is gonna come buy at night and slam into my truck. Any ideas?
Jeremy
I have done so much, for so long, with so little, I can do anything with nothing!
1984 GMC Sierra Classic-1/2 ton-SWB (R.I.P.)
1986 GMC Suburban 3/4 ton 4x4
2014 GMC Sierra LTZ Z-71 Crew SWB
1425956 is offline   Reply With Quote
Old 04-17-2011, 06:01 PM   #2
one low c10
Re: Trans leak from dust shield. Brand new front seal.
front pump or the seal still. did you check the converter to see if it was scored or grooved? if it is, they make a repair sleeve to correct the problem. just my .02 cents
one low c10 is offline   Reply With Quote
Old 04-17-2011, 06:09 PM   #3
Gumby
Gumby's Avatar
worked in a TC shop and those groves and such were just sanded down smooth with emery cloth while it was on the lathe to get cut open.
could catch a good fingernail on some and long as its smooth, it will seal.
Gumby is offline   Reply With Quote
Old 04-17-2011, 06:12 PM   #4
1425956
1425956's Avatar
When you say front pump or the seal...You are referring to 2 different seals? The one I changed is the one you can see that goes around the input shaft. Is there another one? And no, I did not really look at the converter too much..Guess I should have
Jeremy
Old 04-17-2011, 06:22 PM   #5
one low c10
there is a gasket behind the front pump that could be bad too, i would think it would be the seal though. check the converter for any scratches or grooves.
