Old 04-17-2011, 11:47 PM   #1
jwalk
What was I thinking?
jwalk's Avatar
LS with Fast Ez-efi?
As stated looking to see if anyone has done this. I was going to go with a carb to stick with the old look, now I'm thinking about Ez-efi. Wasn't for sure if it's compatible with the edelbrock ignition setup that comes with their intakes.
Thanks in advance!
Justin
'68 C/10 Custom Long wide bed
'78 GMC Sierra short wide
Project: Second time around...'68 short wide
http://67-72chevytrucks.com/vboard/s...d.php?t=423949
jwalk is offline   Reply With Quote
Old 04-18-2011, 07:59 PM   #2
85burb
85burb's Avatar
Re: LS with Fast Ez-efi?
Not sure about the edelbork one but my msd 6010 will work with it i am told. My ez efi master kit should be here on wendsday to put on my carbed 6.0. It is the one in my sig. A few people on ls1tech have it. Not many of them run yet do to still building cars. Got mine from summit cause they price matched atlanticspeeds price.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-19-2011, 09:45 PM   #3
jwalk
jwalk's Avatar
That's sweet! Let me know how it goes and if you run into any problems?
Any one else?
Justin
Old 04-19-2011, 11:18 PM   #4
85burb
85burb's Avatar
I really dont think anyone else has it or would even consider anything other then whay gm put on it. Just doing a carb seems like you joined the dark side. Some people on ls1tech.com have done or are doing it. Tons of people on a corvette fourm have done it on older engines for get the name of the site tho.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-19-2011, 11:25 PM   #5
jwalk
jwalk's Avatar
I know what you mean about that. A few friends that I work with think I'm crazy for wanting to do this. I might have to go look around on ls1tech...
Justin
Old 04-19-2011, 11:28 PM   #6
85burb
85burb's Avatar
I had a thread about a 383 or a carbed 6.0 and 90% of the responses where Why would you downgrade to a carb and so on. Sure the factory set up is the best for milage but driving it looks out of place to me sometimes. Need big aluminum intake under masive steel hood.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-20-2011, 01:35 PM   #7
softballnrd27
Always a work in progress
softballnrd27's Avatar
Why not go with and edelbrock efi intake and a 4150 style TB? I am going to go that route, and it can still be run by the stock computer. Other than the fuel rails it gives it the old school look with modern day mileage.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 04-20-2011, 10:28 PM   #8
jwalk
jwalk's Avatar
I don't think it's downgrading! Their making some serious power out of them! I could go either way (carbed or stock) just depends on how I was building the truck.
The main reason I am going with a carbed intake is to stay looking old school with the modern engine, so injectors and fuel rails won't look right to me. I was going to just run a carb, but this last weekend I played with the FAST Ez-efi and it's pretty sweet! Might still run a carb for a little bit, but I do plan to get the FAST set up. I was just seeing if anyone was already doing it.
Justin
Old 04-20-2011, 11:28 PM   #9
85burb
85burb's Avatar
Well the easter bunny left this for me today. They sure put some time into laying this all out. The throttle body is a piece of art the harness is amazing and the tech. they put in it is superior. Cant wait to install it. I got the master kit that comes with everything you need like hoses, fittings, pump, relay and harness to pulg into the efi harness so no need for any wiring on the pump. Also a regulator and fuel filter. Just amazing.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-21-2011, 09:32 PM   #10
jwalk
jwalk's Avatar
That's what I'm talking about! I'm pretty sure I will be going this route also! Now get that dude installed and let me know how everything goes! Lol
Justin
Old 04-21-2011, 10:44 PM   #11
85burb
85burb's Avatar
Hope i can install it befor the end of next month. I need to with gas prices the way they are. Hope my factory retun line will handle the flow. The return side just uses hose clamps so not thinking it will be a problem.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-28-2011, 01:09 PM   #12
ControlFreak
ControlFreak's Avatar
I have been thinking of doing this also. I can't wait to see how this works for you. Any progress yet?
ControlFreak is offline   Reply With Quote
Old 04-28-2011, 07:27 PM   #13
85burb
85burb's Avatar
Yes....The other day when them tornatos came thew i was sitting in closet and was playing with harness and conected the harness to the ecm and the t/b. I figured out how to wire it in. Trying to find out if the coolant temp sensor for a lq4 is the same resistance as the one in the fast kit. Other then that no.....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-01-2011, 11:38 PM   #14
85burb
85burb's Avatar
Got to install my ecm today. I wanted to put it inside but i could not due to size of hole i would have to cut to fit harness threw. I put it on pass side fender betwen the batt and coolant resivor. Was the best place i could see to put it that would not get it soaked when i went threw a puddle. Also found out that the factory coolant temp sensor that comes in a lq4 is the same resistance as the one that came with the fast kit so that means no adapters are needed. It even plugs into the fast harness. Only 7 bucks too!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-02-2011, 06:01 AM   #15
60ratrod
yes, i do
60ratrod's Avatar
the edelbrock ignition driver should work. i'm working my way to using the mpfi retrofit kit myself. i've been talking back and forth with the tech dept at FAST and there are guys out there using the mpfi kit with the LSx's and they are using the ignition drivers. there shouldn't be a problem with the edelbrock ignition driver, infact i think its an msd unit
ERROR 404....... SNAPPY COMEBACK NOT FOUND
_______________________________________________________________________________________________
-60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination"
-07 gmt900 silverado 1500 lt xcab z71, granite blue
-81 suzuki gs650g "shelah"- current project
-81 kz1000m1 csr "sarge" -next project (just beautification)
-07 kawasaki vulcan classic vn900
60ratrod is offline   Reply With Quote
Old 05-02-2011, 09:00 AM   #16
ControlFreak
Looks good. Keep it up. Can't wait to hear it's running.
Old 05-02-2011, 08:11 PM   #17
85burb
85burb's Avatar
MSD does make the edelbrock controller. The only diff is you can program the msd timing curves. And the timing chips are not the same curves i beleve. I talked to the msd tech and they told me it does put out a V8 square wave signal whitch i beleve is exactly what the fast ecm is looking for.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-14-2011, 08:38 PM   #18
85burb
85burb's Avatar
installed the efi today. Went very smooth. The only problem i found is where i have my coolant temp. The wire bearly reaches it. I will extend it in a few days. Other then that everything is as advertised. You tell it what you want it to do and it does it. After 3 key cycles to prime the fuel system i just bearly bumped the key and it fired like it has had it on there for ever. Idle seatled down to 700 where i told it i wanted it to be and even in gear it idles there with no prob. Can tell it has learned idle better already. My girl helped tons today as well.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-15-2011, 09:43 PM   #19
C10CORIE
C10CORIE's Avatar
Keep us posted on how this system works out please.
C10CORIE is offline   Reply With Quote
Old 05-15-2011, 10:31 PM   #20
Super73
Super73's Avatar
Perhaps I am biased, but this looks good to me (Other than the rusty old headers).. IMO I'd loose the coil packs before the fuel rails.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 05-15-2011, 10:56 PM   #21
85burb
85burb's Avatar
super73 your motor gave the the idea. Have pic of you motor saved to my computer. That thing is a work of art.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-15-2011, 10:58 PM   #22
Super73
Super73's Avatar
Thanks.. The next engine bay clean up thing for me will be relocating the coilpacks and running a sheetmetal alum valve cover. Just need to find time.
Old 05-15-2011, 10:58 PM   #23
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
what throttle body is that?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 05-15-2011, 11:09 PM   #24
85burb
85burb's Avatar
Toilet bowl size
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-16-2011, 12:02 AM   #25
Super73
Super73's Avatar
It's an Edelbrock dominator TB that is said to flow 2k CFM. I really want to get a dominator Intake but there is only one on the market (it's a very nice piece but I can't justify it right now).
