Old 04-18-2011, 01:48 PM   #1
Mikedub82
Mikedub82's Avatar
Steering column
I have a 1966 c10. My bearings are shot(gone) in my steering column. Should I try to change the bearings in the column or get a newer one(70's) from the junk yard. I am upgrading to power steering also. What should I do.
Get Low
Mikedub82 is offline   Reply With Quote
Old 04-18-2011, 03:33 PM   #2
mikie 1954
Re: Steering column
I don't know about the bottom bearing but the top one is not that hard to replace.I did it on mine, no problem. As far as what to do that is up to you but maybe you should look into getting a tilt from a local recking yard, then you would have tilt . Everyone on here say that it's not that expensive or hard to do.
mikie 1954 is offline   Reply With Quote
Old 04-18-2011, 05:11 PM   #3
Mikedub82
Mikedub82's Avatar
Re: Steering column
Thanks, does anyone know how to change the lower steering column bearing
Get Low
Old 05-05-2011, 10:51 PM   #4
aspiringthomas
aspiringthomas's Avatar
Re: Steering column
I am curious what tilt column from salvage would fit a 1965 chevy C-10.
aspiringthomas is offline   Reply With Quote
Old 05-05-2011, 11:28 PM   #5
forestb
forestb's Avatar
Re: Steering column
Ha Midedub82
Do you have side trim on a step side? Do you have any pics from the side?
forestb is offline   Reply With Quote
Old 05-06-2011, 08:27 AM   #6
lakeroadster
Re: Steering column
If you replace it with a junkyard column it too will likely need the bearings replaced.
I replaced the upper and lower bearings in my '65. Takes a couple hours at the most assuming it doesn't have steering shaft wear. Look at posts #25 & #26 in my build thread: Lakeroadster's Build Thread
lakeroadster is offline   Reply With Quote
Old 05-06-2011, 10:10 AM   #7
kieth
kieth's Avatar
Re: Steering column
I used one from a 91 burb, it took a few mods but one can buy them for $75.00 at a salvage. Kieth
kieth is offline   Reply With Quote
Old 05-06-2011, 12:41 PM   #8
Mikedub82
Mikedub82's Avatar
Re: Steering column
I changed the column. I used a tilt column, gear box and shaft from a 84 c10. I had to do some modification to the column to get it to fit. The shaft had to be drilled and collapsed. It looks good and fits great. I just have to get my old steering wheel put on the new column when i get some time.
Get Low
Old 05-06-2011, 04:00 PM   #9
wildearp
wildearp's Avatar
Re: Steering column
Me too. 80's Suburban. The U-joint is just above the entrance hole in the fenderwell. I also cut back the shift ring to allow installing the column as close as possible to the dash for belly room.
wildearp is offline   Reply With Quote
Old 07-28-2011, 10:52 PM   #10
wildearp
wildearp's Avatar
Re: Steering column
