Old 04-18-2011, 04:19 PM   #1
'70GMCStep
Oil pressure on a 350
My oil pressure guage is reading around 30-40 pounds of pressure at around 2000 rpm. If memory serves me, isn't it to be around 50 at same rpm?
I'm running a 350 chevy, 4bbl edlebrock, more of our vintage in heads.
Hoping the aftermarket gauge is not working on the blood pressure side after I disconnected it when painting.
Thanks guys,
'70GMCStep
'70 GMC Short Stepside
'65 Chevy LWB Fleet
'70GMCStep is offline   Reply With Quote
Old 04-18-2011, 04:24 PM   #2
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: Oil pressure on a 350
Idling at 20 pounds of pressure.
Driving anywhere between 40-50 pounds of pressure depending on rpm range.
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-18-2011, 08:35 PM   #3
PGSigns
PGSigns's Avatar
For a standard pump that is about right. Mine is close to that.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-18-2011, 08:57 PM   #4
cableguy0
Thats perfectly fine. Rule of thumb is 10 psi for every 1k rpm is acceptable.You have a healthy engine.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-18-2011, 10:07 PM   #5
jocko
jocko's Avatar
concur, 30-40 is ok at 2K rpm - you may be used to seeing higher pressure on newer engines - or newly rebuilt older engines, but if it aint broke, don't fix it, that's my motto. (but then again, I've grenaded two engines to the tune of an inopportune rebuild and a few $$.... Sooo, disregard everything I just said). (Just kidding, I DO think 30-40 is just fine at 2K)
Old 04-18-2011, 11:10 PM   #6
'70GMCStep
I appreciate the advice guys. I'll relax now.
'70GMCStep
'70 GMC Stepside swb
'65 Chevy lwb fleet bbw
Old 04-18-2011, 11:49 PM   #7
benoit454
Chris
benoit454's Avatar
I always heard as long as you got like 14 or so on idle it's good and as long as it doesn't go to zero while driving etc.
I've had several though, all mech gauges aftermarket,
the 88 k1500 I got runs about 60 cold and stays that way, once warm and idle drops to around 30 or so.
the 86 k10 dad had was around the same, 20-40 warm on idle, 40-60 warm running and driving.
the 84 c10 305 he had runs 25 psi cold on idle, not sure on driving yet.
The motor he now has in his 84 c10 we built for another truck, it runs 50-75 warm on idle, 100-125 cold on idle and revving. it used to stay pegged at 125 cold revving, and would only drop to 100 once warm and idle. Now it's about 10 years old and it drops to around 50 or so once warm on idle. I think he put in a HP pump though, he kept saying it was a HV pump but it's a stock oil pan, I heard you need added quarts to run an HV pump or else you can suck the pan dry.
Chris
GIT R DONE!!!!!!
Check out all our rides,
