04-20-2011, 03:38 AM | #1 |
clutch linkage issues
hey guys i have a 72 c10 long bed with a column shift, now behind the gauge cluster you can see where the clutch pedal goes up above the steering column connects to a shaft that crosses over to the gas pedal area with some linkage where another rod goes through the fire wall and now this is where my problem is: the bar that goes through the firewall has some serious wear issues along with the metal that connects it to the swivel and i have no idea were to get replacements i ordered one from lmc and it is no where near the same ill post some pictures of the parts in question
Uploaded with ImageShack.us |
04-20-2011, 05:25 AM | #2 |
Re: clutch linkage issues
Welcome to the 67-72 Chevy Truck Forums from West Michigan!
What a difference in replacement rod. It sure does not look like it will fit nor have the needed stiffness. Good clutch rods come up on the parts board occasionally so you may want to watch for one. Otherwise joining the board is an option and you can post a WTB. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
04-20-2011, 06:27 AM | #3 |
1969 Custom 30 wrecker
I'd say a junkyard would be your best bet on something like that. Avoid repro whenever possible for the obvious reason.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
04-20-2011, 02:15 PM | #4 |
thanks for the feedback guys and i was going to convert to a hydraulic throw out bearing setup but im trying to get the money together to get to Nebraska i might just re use these parts if i dont find any and do the conversion up there
04-20-2011, 08:12 PM | #5 |
Check the parts board. I know there is at least one for sale there.
-Scott- |
05-02-2011, 12:35 PM | #6 |
I stumbled on the answer one day while helping someone work on a '71 suburban. Shortly after I had installed a motor in my sb I found that it only had one threaded hole above the oil filter that was not directly across from the frame mounted pivot bracket. This is what I did.
Ground off the 2 rivets that hold the bracket to the frame. You should find another hole in the frame about 2 inches down the rail, towards the cab. I reinstalled the bracket using bolts. Put a ball stud in that single threaded hole above the oil filter and attached the clutch linkage. This is where that funky bar comes in. Now I have another 350 sbc with only one hole for my other truck and thanks to this post I know where to get that funky bar.
GENERALM |
05-02-2011, 04:21 PM | #7 |
Scrapper 1
I'm looking for the whole set up On the three on the tree I never every thing from the steering column for a 1972 1/2 ton
05-02-2011, 04:24 PM | #8 |
Scrapper 1
One last thing the guy cut a hole in the floor of this really nice 1972 1/2 and that was me I just rip out the 3 speed and put a th350 or 700R4 in and shorten the drive shaft
05-04-2011, 02:46 AM | #9 |
stsalvage you will be mad at me lol ive done the same thing i switched mine from 3 on tree to the floor but this is only going to be for the next year or 2 once i get a second car im pulling the column out and cleaning it out it was packed with grease by my dad when he owned it and now from the grease drying up you can bairly move the shifter, iva had it pull the shift linkage out while trying to shift before its so bad lol
1972 c10 mild 383 3 speed on the tree It finally happened. I got the GPS lady so confused, she said, "In one-quarter mile, make a legal stop and ask directions." ~Robert Brault, |
05-04-2011, 10:16 PM | #10 |
Watch out for your cornhole !
On the rod, weld up the grooved area and grind it back to shape.
On the lever part, weld the hole up and drill a new one. That should get you down the road another 40 years worth of use.
05-07-2011, 07:54 PM | #11 |
idky i never thought of that thanks fire fighter ill probably do that tomorrow
05-07-2011, 08:39 PM | #12 |
i was just looking at your blog firefighter and i think its what i needed to see to get my motivation back for my truck
Tags |
clutch linkage |
