Old 04-20-2011, 02:41 PM   #26
Clyde65
Clyde65's Avatar
Re: power door locks on a 1965 gmc
what about if your battery goes dead? happens here more than anyone would like to admit.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-20-2011, 03:09 PM   #27
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
two things you could do!
1. have the wire for one of the doors hiden some where on the outside of the truck. im not to sure but i think a 9volt batter can unlock.
2. Or just charge your battery and hit the unlock button
Sick5 is offline   Reply With Quote
Old 04-20-2011, 04:56 PM   #28
jimmydean
jimmydean's Avatar
Do I have to hack to door latches, or can I just lock the button and use the bar on the inside? A stereo shop said that's what they would do, then they would charge me $100 a door to run 2 wires and screw in the actuator to the rod.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-20-2011, 06:54 PM   #29
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
dont know! when i took a look at everything the only thing i can see would be placing it to the handle bar...
Old 04-20-2011, 07:20 PM   #30
jimmydean
jimmydean's Avatar
I don't have a key for my doors, so I have no idea what happens when the door is locked
Guess I need to buy some locks and figure it out from there.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-20-2011, 09:21 PM   #31
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
i dont use my key at all..
when i lock it using the alarm thats it its locked no key can open it unless i unlock it with the alarm
Old 04-20-2011, 11:08 PM   #32
Chevy Fleetside
Chevy Fleetside's Avatar
When I make it back to Stockton I would like to check out your truck. I might be up there around fathers day or the week after but I am not sure.
I usually pick my son up from his Aunt at the Stockton PNP.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-21-2011, 09:44 AM   #33
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
no problem. PNP is on the hwy 99 im next to hwy 5. just send me a msg. and ill give my number
Old 04-30-2011, 02:55 PM   #34
jimmydean
jimmydean's Avatar
OK, this was a lot easier that that write up. I didn't weld anything. The only thing I did was grind out the pin and replace it with a bolt.
Pin removed:
Bent the spoke for the actuator to fit around the lock pin:
Put the hoop over the lock pin:
Reinstall:
Here is the orientation of the actuator in my door
See the screws are hidden by the door panel (ignore the "test" hole):
DONE! The actuator locks and unlocks like a charm. The window clears the actuator and there is no binding at all.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-30-2011, 09:46 PM   #35
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Good job. A lot simpler than mine
i was taking a look at your install again that actually moves the handle when you hit lock right? so you can unlock it with by pulling on your door latch from the inside?
the write up was so that the lock and the handle would be seperate. the handle would only open the truck and the actuator would only lock and unlock.
Old 05-01-2011, 02:47 AM   #36
jimmydean
jimmydean's Avatar
I did what the stereo shop quoted me $100 to $250 per door to do, that was all. I wanted the ability to lock the door from inside with the handle or lock from the outside with/without the key. If my battery is dead, I can still get in/out.
Plus it only took about 20 minutes per door.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 05-01-2011, 12:36 PM   #37
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Old 05-09-2011, 06:50 PM   #38
Joemomma1
Joemomma1's Avatar
Seems simple enough. Sick5 do you mind sending the scanned pages to me? Antzam87@hotmail.com
Joemomma1 is offline   Reply With Quote
Old 05-09-2011, 09:03 PM   #39
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
sorry joemoma i had cleaned out email addy a long time ago ask chevy fleetside i think he sent them to me.
as soon as im doing reduing the rear of my truck ill send some pics of the passenger side wich came out alot better
