I'm looking at extended studs to make a set of custom wheels safer to drive.Anyone have experience with this?Any tech info would be great.Would not do this this way ...emergency situation....any help??1968 2 wd 250 6 with 3 spd standard and these frickin' aluminum wheels previous owner put on...lol
oldschoolblazer@yahoo.com
Re: wheel studs
are we talking up front with rotors ?
if so I have done it before on a rotor worked well.. |
Re: wheel studs
I do not believe that you will find longer studs with the correct knurl size.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
Re: wheel studs
Dorman makes extended studs... just check what the stock application stats are and search their site for the length you need with the same knurl, diameter and thread pitch.
I've done this on many a vehicle with great results. You can get the studs pressed in at nearly any shop with a press, or now you have an excuse to buy your own press. *Not a recommended install, but I've broken studs in the mountains before and pulled them on by stacking washers and cranking down the on the lug to pull it to seat.
1968 Chevy C10: 4x4 conversion, 6" lift, 37" GoodYear Military OZ's, carb'd GMPP RamJet 350, Be Cool aluminum radiator, Flex-o-Lite electric fans, March accessory brackets, T350 trans, NP205, 4 wheel disc, fuel cell... etc. Last edited by HARJO; 04-20-2011 at 06:43 PM. |
