Old 04-20-2011, 11:38 PM   #676
85burb
85burb's Avatar
Re: 85 burb meets 6.0 lq4
YAY its easter early.... Bunny was at my house today. He left this for me. This thing is amazing. I cant beleve how advaced all the wiring is. It a work of art. Uses very nice connectors, all GM sensors so if one fails i can just go to well any were to get new one, plug and play fuel pump harness dont have to wire anything extra for the fuel pump. Just plug the relay harness in and run wire to pump. It can even pump idle up for A/C and controll fan on/off temp has a check engine light. I now see whay it cost so much. Must have tons of R&D time in it. Cant wait to install everything and test it out.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-20-2011, 11:42 PM   #677
my4by2
my4by2's Avatar
Can't wait to see it installed in the truck man!!! Enjoy
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 04-20-2011, 11:58 PM   #678
85burb
85burb's Avatar
Me to. Maybe with this i can ENJOY it more. Cant even make it 2 weeks on tank of gas. I only drive it to work and back. I only live 12 miles from my work. Cant wait!
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-21-2011, 10:39 AM   #679
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Looks great. Hopefully it'll give you what you're looking for.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-21-2011, 11:01 AM   #680
Jonboy
Slots go on anything!
Originally Posted by 68GMCCustom View Post
may have gotten lucky.....one of the shops near me will consider it as a newer model truck if it has a newer engine in it. they make it have all the emissions stuff that came with the engine in the 1st place....regardless of vehicle age!
I wouldn't go there either. Should be safety only on a 68, regardless of engine. If you have all of the required items to pass safety, it shouldn't matter. It's not like California here (yet).
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 04-21-2011, 12:37 PM   #681
kvn1011
Kvn1011
kvn1011's Avatar
Nice!
kvn1011 is offline   Reply With Quote
Old 04-21-2011, 08:05 PM   #682
y5mgisi
Second Chance Program
y5mgisi's Avatar
We cant wait either! When do you think you will have it on?
y5mgisi is offline   Reply With Quote
Old 04-21-2011, 09:47 PM   #683
68GMCCustom
oh I'd bet on this weekend!
Kurt -
Old 04-21-2011, 10:29 PM   #684
85burb
85burb's Avatar
I wish....Stupid easter! Jk i still need to order a nother coolant adaper and get new BUNG welded in. That will mean my burb has 2 BUNG holes. ha ha ha
Well if it does not help milage i will have a really pricey paper weight.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-21-2011, 10:50 PM   #685
MTCK
MTCK's Avatar
What does your rig weigh? Lots of mass is hard to overcome. Our pilot at work has a 2500hd with a 6.0 that gets about 8 mpg around town but he has a 250 gallon 100LL tank in the back. Can't wait to see the install! The quality of that kit looks first class.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 04-21-2011, 11:06 PM   #686
85burb
85burb's Avatar
Think it is about 6000lbs The 5-7 is mix 50-50 street and highway. With old motor i go 8. That was a wore out 350 with rich q-jet. Had to punch it everyware to go.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-21-2011, 11:10 PM   #687
85burb
85burb's Avatar
I could not beleave the quality of the kit. I was expeciting way less. Sad to say but some of the after market stuff is just junk. The harness is first class and all the connectors are what you would find under the hood of a brand new car. Uses all gm sensors and tags on the end of all wires and pig tails. No guessing to where to plug them in. It has a wiring diagram that is exactly the same as what peterbilt uses. So i can under stand it well. It even says the ecu is water tight with the harness connected. Has a 1 year warrenty also.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2011, 09:49 PM   #688
85burb
85burb's Avatar
I do need to get my truetrac installed. I smoked my TIRE therw first and second gear today leaving pepboys. Covered both lanes pretty thick. Smelled great. Have not smelled rubber like that in 4 years when my wife still had her 68 gmc. Brang lots of good memories back.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2011, 10:14 PM   #689
mooseknuckles
mooseknuckles's Avatar
I've heard only good things about the easy efi!
mooseknuckles is offline   Reply With Quote
Old 04-23-2011, 11:34 PM   #690
85burb
85burb's Avatar
Me too. I have read like 10 diff fourms and only had one actual complaint and that was on here. Tons of people have done it on corvett fourms and few on ls1tech and lots of others. I feel confident in the system after looking at the product i was sent. Cant wait to install it.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-29-2011, 09:49 PM   #691
85burb
85burb's Avatar
So i noticed my truck was pinging today on way home. Was in 4th at about 1200 rpm and lightly pushed on pedal and heard it ping. Would i go up or down with the timing. I am pretty sure lowering the number is the right thing to do right.....
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-29-2011, 09:51 PM   #692
mooseknuckles
...retard it! lol
Old 04-29-2011, 09:59 PM   #693
my4by2
my4by2's Avatar
Yep, dial it back a bit & you should be fine - or step up to a higher octane fuel if you're just using the low grade stuff.
Old 04-29-2011, 10:27 PM   #694
85burb
85burb's Avatar
I am using low grade fuel. I will set timing back a few degrees and see what happens. Cant afford higher grade fuel right now and arm and leg a gallon
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-30-2011, 06:38 PM   #695
85burb
85burb's Avatar
So i went to the parts store and asked for a coolant temp sensor for a 03 2500hd with a 6.0 and measured the resistance and found that it has same exact resistance as the one that came with my efi kit.
Also had to take wifes toyota out to pasture and shoot poor thing. We just had new wheel bearing, both front axles and all rotors and pads replaced and now the trans is leaking fluid out the cv axle seals. Has 252,xxx miles on it now so we went to toyota to look at getting different car. Long story short ended up with 05 chevy malibu 4 door LS V6. Was looking at a 03 monte carlo ss but looks like it had ran a full length NASCAR race. Bumper was scratched and paint was rubbed off all over the place. Was a good deal cause i told them what i wanted to pay for a payment and we got a lot nicer car then i had expected to get. Only has 60,xxx miles on it. So did not get any thing done on burb today. Maybe tomorrow
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-01-2011, 01:20 PM   #696
68GMCCustom
glad to hear you got her in something a bit more dependable and safer....is it sedan...or a MAXX...with the adjustable back seat?
Kurt -
Old 05-01-2011, 04:29 PM   #697
85burb
85burb's Avatar
Here are pics. I love the seats and interior colors. Only 60,xxx miles and in perfict condition pretty much. Has clunk when turning that the dealer is going to fix and radio does not accept cds they will fix that as well. Also have 36/36000 warranty that covers everything just like a new car would. And she is off my back about her crappy car. And we are even now.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-01-2011, 04:31 PM   #698
85burb
85burb's Avatar
Also mounted my ecm and set up the harness. Removed few wires that i did not need and shortend my batt wires that power it. Looks like the best place i could put it. Wanted to mount it inside but it is water proof with the harness pluged in to it so outside will be just fine. Hope to finish this month maybe next week end.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-01-2011, 06:38 PM   #699
bayou boy
bayou boy's Avatar
Have to tell you i love the burb6.0 and i used to live in the same park off 155 great thread with info debating my own lsx swap tearing down to the frame now have to wave at ya sometime
all i know is that its going to be orange
bayou boy is offline   Reply With Quote
Old 05-01-2011, 07:59 PM   #700
85burb
85burb's Avatar
Sure dont live there any more thank goodness. Our trailer was in need of a big dumpster. The park was ok but our unit was smooth wore out. The owners were ok as well. What trailer did you live in.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
