04-21-2011, 07:20 PM | #1 |
Door Weather Stripping
Could someone please post a picture of their single wall top to door glass weather stripping where it goes over the drip catcher. I've got new seals and that looks pretty straight forward, but I also have a set of drip catchers to install and I don't want to figure it out the hard way (by doing it wrong the first time). I take it the drip catchers do in first then the stripping goes on top of them. I would use the weather strip glue on the top. and then when I remove it the drip catcher would go stay on the top?
A close up pic. of that area would be great. I did a search but the only pics I found were not displaying (X). Thanks, Gibber |
04-26-2011, 12:06 AM | #2 |
Re: Door Weather Stripping
Bump...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-28-2011, 05:49 PM | #3 |
Nice try 70CST. I really thought this would be an easyone for somebody....guess not. Is nobody running the drip catchers? I had them on a previous '72 Jimmy and I thought they worked quite well.
05-04-2011, 10:09 AM | #4 |
I thought I would take a picture of the area I am talking about. My top is off but I would prefer to see a picture of this area with the top on and the drip catcher installed,,,,,please?
Thanks, Gibber |
05-04-2011, 11:25 PM | #5 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
05-05-2011, 12:50 AM | #6 |
That's what I'm talkin' about!
Thanks BobbyK, Gibber |
05-05-2011, 09:00 AM | #7 |
2WD Jimmy
Wow... I hadnt seen that before. So... everytime you remove your single wall top, you have to thread that aparatus in there and screw it down... or am I just looking at it wrong?
Thanks, Tom |
05-05-2011, 10:08 AM | #8 |
Ya, pretty much. On my last Blazer I just left them attached to the top so I had to put the two screws into the window frame every time I put the top on. Not a big deal really for me since I usually just take my top off in the spring and put it back on in the fall.
05-05-2011, 11:10 AM | #9 |
The two screws that thread into the window frame need to be removed before top removale.
05-05-2011, 06:38 PM | #10 |
Are those deflectors the same for a double wall top? Thats how I have mine set up and it leaks.
05-06-2011, 01:05 AM | #11 |
To be honest. I think the tops leaked from the factory.
05-06-2011, 12:04 PM | #12 |
Back in the sticks
What kind of weatherstip adhesive are you guys using? I used the black 3M stuff and it only lasted a little while before all my weatherstrip came off. What kind is the best for lasting? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
05-06-2011, 01:51 PM | #13 |
I used the black loctite kind and the 3m stuff. The loctite seems to hold a little better.
Posted via Mobile Device |
05-06-2011, 02:13 PM | #14 |
I have found that the weld wood contack cement beats everything else for ease of use and holding.
05-06-2011, 03:38 PM | #15 |
are you putting it on both surfaces, letting it tack up, then assembling it? That's the way it was described on My Classic Car...
05-06-2011, 04:23 PM | #16 |
Saw that one too: seem to work good
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
