Old 04-21-2011, 07:45 PM   #1
Mr. 250r
Mr. 250r's Avatar
Dana 60 swap
A little story before i go into actual swap my brother decided to go through the coal mine pit i told him he would not make it through so he gets stuck, i attempt to pull him out and it breaks his front tow hook and the barge rope hits my back door and destroys it and the back left pillar is now dented
Then i tried pulling him out the other way which broke my passenger front axle so i called it quits for the day and looked for a new axle later but found a FF 14b and D60 from a guy on here, bought them went and got them and started the the D60 swap today
Mr. 250r is offline   Reply With Quote
Old 04-21-2011, 08:08 PM   #2
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
Out with the old and used the strongman to move the new axle around, didn't take but a few hours because it was the first time and did through trial and error but of course my u-bolt kit was wrong so i have everything done except the passenger side u-bolt
Old 04-21-2011, 08:09 PM   #3
Davidmichael
Davidmichael's Avatar
Re: Dana 60 swap
looks good. I am starting the same swap. I will be watching this.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 04-21-2011, 08:41 PM   #4
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Dana 60 swap
Very nice and sweet rig!
Ryan
1969 Chevy milk truck
Old 04-21-2011, 09:13 PM   #5
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
unfortunately not much to follow lol it was the easiest thing I've ever done im having a harder time with bucket seats but i still gotta figure u-bolt problem and just tighten up shocks, brakes get the steering block and put the front drive shaft back in, and thanks diesel sucks i took through an atv trail got all kinds of dents and scratched and the back door dent *Little update emailed company about u-bolt problem and he is sending me correct size tomorrow so i won't be able to drive it till like wednesday or thursday* but i can mess with FF axle until then
Old 04-22-2011, 09:09 AM   #6
Davidmichael
Re: Dana 60 swap
that's ok. Still sweet. Scratches and dents give vehicles character. Must be great to have the lifts handy.
01 S10 ZR2
Old 04-22-2011, 09:23 AM   #7
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
yes that is a plus to my dad having a transmission shop whenever there's a rack open i get to use it but the strongman lift i used for axle never gets used
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Old 04-22-2011, 03:23 PM   #8
Dieselwrencher
Re: Dana 60 swap
Yeah, hoists are sweet! That strong man would be awesome too! Everything I work on is heavy. The 5R110 we put in the bacl of my truck the other day will make ou think twice for an auto.
Ryan
Old 04-23-2011, 01:49 PM   #9
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
Unfortunately not only is the passenger side u-bolt wrong the bolts are also too long but they sent me a new u-bolt hopefully of right size and i can put a washer on the bolts to fix it for now and i also didn't get my kingpin block on Friday like i was supposed to to which is no surprise but here's some pictures of the old stuff that came out, barge rope that hit my door and my axle after i broke it
2003 1500 Silverado
Old 04-24-2011, 07:35 PM   #10
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
Re: Dana 60 swap
That Suburgan looks sweet!
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 04-26-2011, 08:03 PM   #11
Dieselwrencher
Re: Dana 60 swap
That axle looks sweet! I just blew the rear u-joint on my 95 F-350 hauling a trailer saturday. What fun.
Ryan
Old 04-26-2011, 08:21 PM   #12
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
unfortunately i tried putting on the steering block and of course finally something went wrong the last stud nut stripped so a friend is gonna try and get it off while im at work then if it is off i can get steering done and new u-bolt should be here tomorrow or thursday to finish axle swap
2003 1500 Silverado
Old 04-27-2011, 08:50 PM   #13
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
made some progress today got the broken stud nut off then used a 5ft 1/2in ratchet and a very nifty stud removing piece and the studs came right out but now i need a bushing that goes in there and then put the driver side together, got the new u-bolt in but of course two bolts being too long wouldn't let the spring plate sit down all the way so rather than spacing them i just bought two slightly shorter grade 8 bolts for 5$ here's the steering block installed, and i was wondering in that last picture is that a steering brace because im pretty sure its bolted in while all the other stock stuff is still riveted
2003 1500 Silverado
Old 04-28-2011, 07:44 PM   #14
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
Swap is finally done everything is bolted up just needs an alignment and i fixed the transfer case leak while i was down there all the bolts were loose so now im leak free and fixed the license plate light which was unplugged, and the next part is the rear axle that came in the set G80 14b FF getting disc brakes and it sits next to the small graveyard of suburban 3/4t axles
2003 1500 Silverado
Old 04-30-2011, 08:00 PM   #15
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
Drove it for the first time and of course something is wrong lol it wobbles really bad at random speeds and sometimes has a weird clunking feeling when turning as well but hopefully the re alignment will solve some issues if not im gonna be spending more money, here's a picture of it outside next to my old suburban
2003 1500 Silverado
Old 05-05-2011, 09:44 PM   #16
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
unfortunately i have the wobble of death issue common with the 1 tons i didn't tell the alignment shop but they are going to look at it check the kingpins, realign it free as well and then check some of the other problems related to the wobble, on another note all the dana 60 stuff fit like stock including stock brake lines with a 4in suspension and 3in body, u joint fits as well, everything but passenger side spring plate
2003 1500 Silverado
Old 05-05-2011, 10:10 PM   #17
TheWhiteElephant
God is good!
Re: Dana 60 swap
Yeah, it sounds like the kingpins need replacement.
Mando
Old 05-06-2011, 12:10 AM   #18
rjn72
rjn72's Avatar
Re: Dana 60 swap
not the actual kingpins, just the kingpin springs. I did it, it fixed it. That two new tires and an alignment equalss no more wobble. Also, the bigger the tires, the more likely to wobble.
JESUS IS LORD
87 crew cab V30 454/400
rjn72 is offline   Reply With Quote
Old 05-06-2011, 08:41 AM   #19
Burt4x4
Burt4x4's Avatar
Re: Dana 60 swap
I know you said no more money butt...I would save up for crossover steering and eliminate thoes pesky springs all togeather!! Never get the wobble of death again
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-06-2011, 11:18 AM   #20
1968vetL-71
Junior Member
1968vetL-71's Avatar
Re: Dana 60 swap
Are the front U-bolt plates from Sky Manufacturing? I just ordered those big beefy D60 plates that are 5/8" thick!! Dang those things are Heavy Duty!! Can't wait to bolt them up! Your suburban looks good, great build!!!!!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 05-08-2011, 04:18 PM   #21
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
i was gonna do crossover until i saw what it does to steering box part of frame even with the brace with a brace i dunno and its more money i gotta spend when im trying to save up for motor, and no 68vet they are 4wdfactory
2003 1500 Silverado
Old 05-08-2011, 10:35 PM   #22
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Re: Dana 60 swap
I've ran crossover steering on my K/30 for over 2 years with no frame issues, and I have a brace just never got around to installing it. Is this a problem on hard core 4 wheelers?
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 05-10-2011, 04:18 PM   #23
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
i can't say 100% for sure because i never ran it but from just researching it people say that it stresses the frame in the steering box area and just big tires apparently does the same, but right now my truck turns left and right fine no huge ass right turn or whatever so ill stick with stock until something happens
2003 1500 Silverado
Old 05-11-2011, 10:06 AM   #24
Burt4x4
Burt4x4's Avatar
Re: Dana 60 swap
What your hearing is not because of switching too crossover. The steering box can be and does get rippped off the frame with factory steering. I have seen it happen. It is the larger tires/lift and rock crawling that puts the steering box at risk most of the time. FOr ANY offROad Chevy, mudd or rocks or firetrails or whatever I would add a steering box brace, plate, gusset..whatever you wana call it. The frame WILL crack and if gone undetected that box will ripp off. Leaving behind 50c piece size jagged holes in your frame were the steering box bolts use to bee
I'm just sayin.....
Crossover with Hydro Assist will greatly reduce the stress your steering box/frame has to deal with.
Old 05-13-2011, 08:29 PM   #25
Mr. 250r
Mr. 250r's Avatar
Re: Dana 60 swap
Well after talking to the 4wd place and seeing what he said they suggested a dual steering stabilizer because the 1 tons are notorious for doing this so he said they recommend the bds one which i got and it fixed my problem, haven't got above 45 but haven't had a wobble below that either
2003 1500 Silverado
