#426 |
6>8 Plugless........
![]() Join Date: Sep 2007
Re: 1969 Short Wide
Looking great! What's your estimated launch date?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#427 | |
Still Learning
Re: 1969 Short Wide
Thanks!
Thanks Scott, I need you to keep an eye out for me a posi, unless you have one stashed somewhere you can sell. ![]() |
#428 |
Still Learning
Re: 1969 Short Wide
Hmmm? That's a good question. I went over my punch list today. It really depends on extra cash more than anything right now. Hope to be cruising by this time next year. We'll see.
#429 |
Laid Back
![]() Join Date: Apr 2010
Re: 1969 Short Wide
Looks like it's almost ready for some sheet metal
Posted via Mobile Device |
#430 | |
One day...
Re: 1969 Short Wide
![]() I have one but its for a ferd 9" but dont think i have one for a 12 bolt.. ill look and make some calls and see what we cant come up with. |
#431 |
![]() Join Date: Dec 2006
Re: 1969 Short Wide
Frame looks really nice, I really like your homemade panhard bar. Nice job keep up the good work.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#432 | |
Still Learning
Re: 1969 Short Wide
Thanks, I am working on this a little every chance I get just not much to update with pics yet. |
#433 |
Still plays with trucks
Re: 1969 Short Wide
So what is next now that it is a roller?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
#434 |
Still Learning
Re: 1969 Short Wide
Well I'm still working on the chassis. I got the tranny xmember blasted, primered and painted (forgot pics). Next plan is to get a new gas tank not sure which one? Leaning towards a blazer tank. I wanted to make my own but kinda doubt that's going to happen now.
I finally saved up enough to buy some brake lines. I ordered a stainless kit from Inline Tube. They were highly recommended from several members. The quality is very good but the fit has been less than perfect. I'm still fighting with them. Part of the problem, my frame is from a 67 and the lines are for a 72. Here are the update pics. I started installing the brake lines and figured out the 67 lines run behind the cross member and 72 runs in front. So I got some line mounts from a fellow board member Kyle (screaminchevypickup) Thanks again! ![]() ![]() I welded the holes up from the rivets ![]() Cut off the old tabs ![]() Installed the new mounts ![]() ![]() ![]() ![]() ![]() Still need to drill a hole in the rear crossmember and fab a mount: ![]() Here is a picture of where I'm having issues with the lines: ![]() |
#435 |
Re: 1969 Short Wide
Looking really nice Mike, great work.
#436 |
Laid Back
Re: 1969 Short Wide
That's one of the problems I have ran into mike with the inline kits
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
#437 |
Newbee
Re: 1969 Short Wide
Nice job! I wish that I had the patience it took to make that panhard mount, and that extension for the bar. I kinda get the job done, but it aint that pretty. I can't wait for you to stick some tins on that thing.
Keep up the good work! |
#438 |
Re: 1969 Short Wide
It's looking great. Those lines loook nice but also looks like they could be a PITA to get installed due to their pre-bent nature.
#439 |
Re: 1969 Short Wide
Nice work,keep the pictures coming & keep on truckin'
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
#440 |
Re: 1969 Short Wide
#441 | |||
Still Learning
Re: 1969 Short Wide
Thanks bro! Thanks! |
#442 | |
Re: 1969 Short Wide
#443 |
Re: 1969 Short Wide
That's crazy. I'm sure they have a lot of unhappy phone calls come through their lines.
#444 |
Truck and auto performance nut
Re: 1969 Short Wide
I had a similar problem when installing my brake lines. They were for a '72 which is the hardware on the frame....but the frame itself is a '68. I wound up having to use an adapter here and there but got it all in. Couldn't use the m/c lines tho since I'm using an adjustable prop. valve.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#445 | |||
Still Learning
Re: 1969 Short Wide
#446 |
Still Learning
Re: 1969 Short Wide
Okay finally got all the brake lines in and mounted (thanks Kyle for the Help). I also got a new tank (thanks again to Kyle (screaminchevypickup). I ended up going with a blazer conversion tank. I wanted to build my own but I moved on. Here are the pics sorry some are blurry:
Drilled the rear crossmember for the brake line 72 style ![]() ![]() Modified the bracket cut off the front: ![]() ![]() Made some gas tank flange straps to spread the load on the mounting bolts: ![]() Bolted to the xmember: ![]() ![]() Brake lines done finally: ![]() ![]() ![]() |
#447 |
Still Learning
Re: 1969 Short Wide
More pictures:
New gas tank kit: ![]() Painted: ![]() Still need to tweak things a little: ![]() ![]() |
#448 |
Still Learning
Re: 1969 Short Wide
Oh and one more area51 development project:
#449 |
Man of Mini-Talents
Re: 1969 Short Wide
That's coming along real nice!
Where are you placing the fuel door / cap?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
#450 | |
Still Learning
Re: 1969 Short Wide
I'm unsure of where I'm going to put the filler. I might run it over to the left inside of the bed or may just cap off this filler and add another that goes straight up? I haven't done much research on this yet. |
