04-22-2011, 01:15 AM | #1 |
Lowering Springs
I did a search and didn't find what I was looking for does anyone know can you just pop in a set of lowering springs say from Hotchkis to achieve a nice drop on a C20? I am buying one and want to save up for the whole kit to convert it over but it's like 5500.00 from Hotchkis so for the time being can I just swap springs to achive my desired stance without changing over all the control arms and spindles and axles to C10 gear? Any advice appreciated. Thanks in advance.
04-22-2011, 01:42 AM | #2 | |
60-66 Nut
Re: Lowering Springs
Yes you can install lowering springs in your C20 without spending a bunch of $$. Lowering springs are available from several sources, and as far as I know the lowering springs for a C10 will work on a C20.
04-22-2011, 01:46 AM | #3 |
You pretty much have to use C10 lowering springs don't you? Or does someone make a C20 specific lowering spring I googled but didn't find anything just bags and the kit like from Hotchkis. Thanks
66 C20 LWB CS 327/TH400 A/C |
04-22-2011, 01:56 AM | #4 |
60-66 Nut
Did you look at
http://classicperform.com http://earlyclassic.com http://www.classicparts.com There are many other sources for springs also. Have you checked out the suspension section here on the forum? There is a thread over there titled "Make it handle" written by Rob at No Limit Engineering. Before you spend as much money as Hotchkis wants for that kit, I would suggest doing some research here on the forum. I believe you could get similar results for a lot less money using less expensive parts.
04-22-2011, 02:11 AM | #5 |
60-66 Nut
Another place to look fro your front suspension upgrade is http://www.porterebuiltstreetrods.com He is a vendor here. His specialty is a bagged dropmember, but he was working on a similar dropmember with coilovers. His products aren't cheap, but they sure are nice, and they work well. It just depneds on your budget and what you want.
04-22-2011, 02:13 AM | #6 |
60-66 Nut
And here is a thread showing a little DIY info for converting to front coilovers if you have some fabrication skills.
http://67-72chevytrucks.com/vboard/s...light=coilover
04-22-2011, 11:02 AM | #7 |
Thank you for all the info will do some reading and as far as Hotchkis I just like the completness of their kit but not an absolute have to have for now was just wondering about a straight spring swap and realign to get it down while I save for a conversion.
04-22-2011, 11:56 AM | #8 |
I installed front drop springs in my 63 and kept the stock drum spindles for now. I have had no issues. I used 3" drop springs from CPP
Betty : '63 Fleetside Longbed 350 w/ 4 speed CPP 3/5 drop with front sway bar. |
04-23-2011, 12:16 PM | #9 | |
Nice looking truck! If you’re simply looking for lowering springs, we offer a spring kit that lowers the front 4-inches and brings the rear down 6-inches from stock ride height. http://www.hotchkis.net/6772_c10_spo...l_springs.html Here’s Rob Phillips’ C10 out at Del Mar a couple of weeks ago. Rob spent a long time mixing and matching parts for along time, he decided to install our TVS kit and has been extremely happy with it and competitive on the road course and at autocross events. We build all of our parts to work together. If you have any questions, call our tech department. It’s toll free. 1-888-735-6425 |
04-23-2011, 07:07 PM | #10 |
I also went with the springs, 2", stock spindles for now, with no problems. Wish I would have done the 3" though. They also have the disc brake kits with the drop spindles ... think I will go with the disc/2" drop spindle kit when I get some $$$, price not that bad, $650
04-23-2011, 07:28 PM | #11 |
Were you able to just pop the springs in and as for the spindles do they make a disc brake drop spindle that will work with the C20 upper and lower control arms or do you have to swap to the C10 arms?
04-23-2011, 08:03 PM | #12 |
Check out ECE here the link call them monday they will answer all questions
http://www.earlyclassic.com/catalog....ry=Drop%20Kits
http://67-72chevytrucks.com/vboard/s...ban+Retro:fro: |
