Old 04-23-2011, 12:36 PM   #1
HERB
spindles and whith
I just finished mocking up my front suspension on my 65 sub. Control arms and drop spindles from 87 sub. Well I hung a fender and discovered that now my front end is wider than the stock rear dif. My question is, is there a way to narrow the front end back to stock whith? 1 1/2 rotors by the way. thanks.
HERB is offline   Reply With Quote
Old 04-23-2011, 03:55 PM   #2
Slow Build
Slow Build's Avatar
Re: spindles and whith
Most dropped spindles will move your wheels out 3/4" per side. CPP modular spindles only move them out 1/4" per side. I know that's not what you wanted to here since it sounds like you already have your spindles but I dont know of any other way to give more fender clearance other than narrower tires.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-23-2011, 09:21 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
Thats the first thing ECE will tell you before you convert to disc...
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-24-2011, 12:40 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
Section out your control arms.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 05-04-2011, 02:48 PM   #5
HERB
I took the spindles to the machine shop and had them move the holes for the ball joints in 3/4 inch. Problem solved everything bolted back up perfect. No more four wheel drive look. Happy but poorer now.
Old 05-04-2011, 03:30 PM   #6
Slow Build
Slow Build's Avatar
Got pictures?
Past GM Trucks:
Old 05-04-2011, 04:09 PM   #7
kieth
kieth's Avatar
I think you will find the 87 front end was also 3/4" per side wider....
kieth is offline   Reply With Quote
Old 05-05-2011, 09:13 AM   #8
HERB
Slowbuild, I did not take pictures. I knew if I didn't I'd wished I had. What he did was make plugs for the old holes and milled new ones.
Kieth, I beleave the difference in width is in the spindles. I did not change crossmember only control arms and they measured the same lenth. It must be to make them the same as the rear dif. width.
There must be others who have fixed this. I am not building a show outfit I just know what I want.
Old 05-05-2011, 09:31 AM   #9
kieth
kieth's Avatar
OK, I had not realize that was where the width increase was, I am having the same problem u are with wheels, might look into machining it out......Thanks, Kieth
Old 07-07-2011, 11:28 AM   #10
HERB
Pictures of new ball joint mounted in new holes.
Old 07-07-2011, 12:03 PM   #11
neslie
I got my disc kit from pol with 1 1/4 rotors. Do these have the same problem?
neslie is offline   Reply With Quote
Old 07-07-2011, 12:09 PM   #12
lolife99
67-72 parts collector,…
lolife99's Avatar
It was always wider in stock drum brake form.
The disc brake/drop spindle combo make it worse.
Porterbuilt Fabrication sells 1" narrower tubular a-arms.
CPP sells a 2" Modular drop spindle that will bring you back close to your drum brake width.
Keith
Convert to disc brakes.
Old 07-07-2011, 12:11 PM   #13
lolife99
lolife99's Avatar
Same as all others with the exception of CPP's 2" Modular drop spindles.
Keith
Old 07-07-2011, 10:46 PM   #14
oldtrux
oldtrux's Avatar
after reading this thread i ran out to the garage and started measuring lol.i have ec's drop spindles,also got there 5 bolt replacement axles.front is 64 1/2'' rear is 63 1/2.is a half inch on either side a really big deal for tires?just asking.....just to understand,lolife you are saying that originally the front was a little wider than the rear?do you know how much?
oldtrux is offline   Reply With Quote
Old 07-07-2011, 11:07 PM   #15
markeb01
Senior Enthusiast
markeb01's Avatar
I put a 1975 front end under mine back in 1997, and never noticed it was wider until reading about it on this forum over a decade later. It can become a critical issue depending on how much the front end is lowered, and may require careful attention in selecting wheel offset and tire size.
Old 07-07-2011, 11:13 PM   #16
oldtrux
oldtrux's Avatar
i see your point markeb01,i guess no wheel and tire purchases for me until truck is put back together.thanks dan
