Old 04-23-2011, 01:01 PM   #1
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
Pinging noise, possible spark knock?
Theres this really annoying pinging noise, it happened even before i put my new cam in, i can cruise and wont hear it but i have a 383 so like to "get on it" and when i do soon as it shifts into 2nd gear i get this pinging/rattling noise and i know it is NOT and rod knock im being told its a spark knock anyway its annoying as all hell and im not sure how to get rid of it i mean **** im runnin 93 octane too. Any help would be appreciated
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 04-23-2011, 01:54 PM   #2
PRattenbury
Re: Pinging noise, possible spark knock?
Use a cooler heat range plug. Go down one range. If it seems to help but not all the way, drop another one (don't go more than 2 heat ranges cooler on the plugs). Use 93 octane gas. Make sure you're not running too lean. And if all that fails, try retarding your timing a bit. If it still pings after all that, get used to the ping. Your compression ratio is probably too high for pump gas.
PRattenbury is offline   Reply With Quote
Old 04-23-2011, 02:08 PM   #3
383Chevy
383Chevy's Avatar
Never thought about the plugs, i will try that and the carb prolly is running a lil too lean thanks
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 04-23-2011, 03:31 PM   #4
cableguy0
Need more info.. What is the compression ratio? WHat are the engine specs? Where is your timing set? What kind of carb and what size is it?
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-23-2011, 09:04 PM   #5
85Bowtie
85Bowtie's Avatar
What heads, pistons and head gaskets are you using? How far in the bore are the pistons? Your problem may not be compression, but instead lack of quench. Many people mistake pinging to be related to having too much compression when most times it's too much heat soaked into the combustion chamber. A higher octane fuel could help resist the extra heat, but that doesn't mean your compression is causing the problem.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-23-2011, 09:50 PM   #6
mooseknuckles
mooseknuckles's Avatar
check timing!
mooseknuckles is offline   Reply With Quote
Old 04-25-2011, 09:17 AM   #7
Blue Chevy 1987
Blue Chevy 1987's Avatar
could be a headstud or pushroad, rocker arm
Blue Chevy 1987 is offline   Reply With Quote
Old 04-25-2011, 09:26 AM   #8
BigBlocksRule
Double check vacuum advance on your dizzy, too. If you're running the same carb with the same settings you had with a 350, you're probably running lean when you get on it.
Get it fixed, detonation tears up more engines than all other causes!
BigBlocksRule is offline   Reply With Quote
