Old 04-23-2011, 04:44 PM   #1
Gyawo
Dash "cage"
I am currently in the process of taking my dash apart to clean behind it. I have the pad off and it is the metal "dash cage" underneath it that I am wondering how I get off. There are two bolts on either side of it that bolt into the body of the vehicle. It is loose now but the top of it is underneath the window gasket. Can I just rip this gasket out and then I will be able to take the "dash cage" out? Or am I SOL?
Gyawo is offline   Reply With Quote
Old 04-23-2011, 05:12 PM   #2
csb#356
Re: Dash "cage"
Underneath the window seal there is some spot welds that you would need to chisel off.
csb#356 is offline   Reply With Quote
Old 04-23-2011, 05:13 PM   #3
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Dash "cage"
Not worth it just to clean, it's a fairly difficult ordeal just to get a few dust bunnies.
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 04-23-2011, 05:21 PM   #4
Gyawo
Re: Dash "cage"
few dust bunnies.
It is actually mice s**t. I am trying to clean up after my previous inhabitants. It is all along the top of the main heater box, so getting that part out would allow me to clean a hell of a lot easier. I will have to contemplate on how motivated I feel to do that though.
Thank you for the replies.
Grant
Old 04-23-2011, 05:25 PM   #5
cableguy0
Re: Dash "cage"
If you had mice in it yanking the heater box is pretty much mandatory. I will bet they nested inside and its packed full of all sorts of stuff. the truck will never have decent working heat.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 04-23-2011, 05:34 PM   #6
csb#356
Re: Dash "cage"
Yeah I agree pulling the heater box will be much easier than taking that metal dash off. And also leaving nesting in there could be a nice little fire hazard underneath your dash. I'm actually redoing the interior in mine right now for that very reason. haha
Old 04-23-2011, 05:37 PM   #7
Gyawo
Re: Dash "cage"
Yea that is what I want to do, I have all the vents except the main one that looks like it is riveted in the firewall out. Getting that cage out would allow me to vaccum out the main box and then disinfect it. I also bought this odour stop bomb that you put in the vehicle while it is running with the a/c and fans on high, supposed to circualte through the vehicles and elminate odours.
Old 04-23-2011, 05:41 PM   #8
Pop's C-10
Pop's C-10's Avatar
Re: Dash "cage"
It will be less PITA to just pull tha box out & cleal it outside tha truck..
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 04-23-2011, 05:59 PM   #9
Gyawo
Re: Dash "cage"
How exactly do I pull the box? It looks like it just has large rivets on it, there are no bolt heads inside the vehicle. Is there nuts on the firewall or a/c and heater motor area?
Old 04-23-2011, 06:07 PM   #10
csb#356
Re: Dash "cage"
To take out the box on the inside there is nuts on the firewall side that hold it on. to get to one of them you have to drop your passenger side inner fender. I believe there are only three nuts.
Old 04-23-2011, 06:17 PM   #11
Gyawo
Re: Dash "cage"
Cool beans. Thank you all for the info/help.
Grant
Old 04-23-2011, 10:34 PM   #12
Brian76GMC
Brian76GMC's Avatar
Re: Dash "cage"
A spotweld drill bit would be a better option if the dash is to be reused.
The drillbit will only take out the metal from the original weld leaving old metal underneath to reweld to.
79 Chevy Big 10
350/T350
My GMC's that I sold
Brian76GMC is offline   Reply With Quote
Old 04-25-2011, 12:20 AM   #13
rayfinseats
Re: Dash "cage"
I just took all my heater ducts out. Not that hard. See
http://67-72chevytrucks.com/vboard/s...d.php?t=460942
rayfinseats is offline   Reply With Quote
Old 04-25-2011, 12:25 AM   #14
Mike Bradbury
Mike Bradbury's Avatar
Re: Dash "cage"
Do you have factory air? One hood hinge has to be removed IIRC.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 04-25-2011, 09:03 AM   #15
Gyawo
Re: Dash "cage"
It does have factory air. I will have to take another crack at it sometime this week after work. The less I have to take off/apart, the better.
