Old 07-20-2003, 09:47 PM   #1
ddsmith
Glowing since 1978
ddsmith's Avatar
What does this do?
So what is the purpose of the damper in the cowl area and is it open or shut with vacuum applied. It's the one attached to the other end of the diaphragm in the top corner of this picture.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 07-20-2003, 09:54 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A/C component. Can't tell you what it actually does though.
Old 07-20-2003, 09:59 PM   #3
racedvl
racedvl's Avatar
It is for max a/c. That will close so no outside air enters the cab, the same reason the kick panel floor vent is vacuum controled.
racedvl is offline   Reply With Quote
Old 07-20-2003, 10:10 PM   #4
ddsmith
Glowing since 1978
ddsmith's Avatar
Thanks racedvl,
So the way I understand it is that the cowl vent draws some replacement air into the cab but in max air position it closes. The big question is where does the air actually enter at.
Old 07-20-2003, 10:17 PM   #5
casey
casey's Avatar
well on my wifes bronco that gismo that is vacuum controled shuts the hot water off from even entering the heater core, if I see it right
casey is offline   Reply With Quote
Old 07-20-2003, 10:18 PM   #6
jef5150
Inline 69
jef5150's Avatar
diagrahm
help???????
jef5150 is offline   Reply With Quote
Old 07-20-2003, 10:23 PM   #7
Class of 69
Class of 69's Avatar
On the original heater box, it was pulled in from under the cowl, thru the hole in the fire wall by the fan. You have eliminated that hole with the plate on there now. Does that install have a fan that pulls air from outside at all??!!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-20-2003, 10:52 PM   #8
ddsmith
Glowing since 1978
ddsmith's Avatar
Class of 69,
That is correct it doesn't pull in outside air but I think I have a possible resolution. The kick panel vent that is vacuum controlled could be left operational and you could select the amount of outside air via the upper control on an A/C control panel. The A/C people want their units to cool really good. They attempt to stop all outside air from entering the cab. I understand why they look at it in that way. They don't want you to complain because the unit isn't keeping you cool enough. If your drawing in 95-100 outside air you pose a very large load on the system. Your house doesn't draw in outside air with your A/C system does it? Well it may if you've got one of those real expensive setups. Most of us rely on leakage and the opening and shutting of doors to exchange the air.
