04-25-2011, 11:44 AM | #26 |
Re: Need help with caster adjustment
Just to make sure we are talking about the same thing....go ahead and make fun of my "paint skills"
Can I have a shop cut that off at the factory weld, rotate 1/2" and re-weld? |
04-25-2011, 08:39 PM | #27 |
Local Redneck Authority
you're on the right track. since it's a 3/4 ton the housings should be a dime a dozen wether it's a D44 or a 10 bolt. You could definitely have a shop cut the knuckle off and have it rotated/re-welded but for the price of sourcing a junkyard core housing I'd lean towards that route. You're going to need the same tools to get the housing down to the point of cut/weld as you would to just swap the guts into another housing. You would need to check your gearset when installing in the "new" housing but that's simple if you read up on it. An no teasing an MS Paint pic if it gets the point across!
-Kevin four on the floor feel the beat in your soul movin to the rhythym pumpin til ya cant take no more dance if you want to do what you came to you cant ignore the feeling of that four on the floor |
