04-25-2011, 07:44 PM | #1 |
Engine Paint
I was wondering what everybody is painting there engines with. Last time i used spray bomb engine paint it started peeling after 6 months. Any suggestions i saw the por 15 but was just going to ask everybody here what they use.
04-25-2011, 07:45 PM | #2 |
Re: Engine Paint
Duplicolor engine paint from kragens.
04-25-2011, 07:50 PM | #3 |
Re: Engine Paint
I agree with Newtz duplicolor engine paint has always given me great results and last for a long time I personally done 3 or 4 engines including heads and intake and they still look great without peeling or chipping
1969 Chevy C10 Short Step -Project 2005 GMC Sierra Crew Cab 1500 -DD 2017 Laguna Orange Roadglide - Good Weather DD |
04-25-2011, 07:59 PM | #4 |
Re: Engine Paint
I know a good paint job begins with good surface prep.
How are you guys prepping the motors before using the Duplicolor? I am building a vortec motor and have been pondering this myself. |
04-25-2011, 08:03 PM | #5 |
Re: Engine Paint
I have used spray paint a lot and have never had it peel. If yours is peeling you need to do a better job with the prep. I would wash and degrease with a high pressure washer and use a scrapper on the areas that are peeling and use a little primer in the bare metal areas. I use Plasti Kote, I like the Chevy orange
04-25-2011, 08:03 PM | #6 |
Re: Engine Paint
With duplicolors prep spray. Good stuff, and use their engine paint primer first. USE THE instructions on the can. Trust me it matters.
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 |
04-25-2011, 08:48 PM | #7 |
Re: Engine Paint
thanks
04-25-2011, 09:43 PM | #8 |
Re: Engine Paint
The only engines I've ever painted were hot tanked prior to painting, except for my brothers. His, we just used degreaser, then soap and hot water if I remember correctly. Engine still looks great after a year.
04-25-2011, 09:47 PM | #9 |
Active Member
Re: Engine Paint
I use the purple soap on it and pressure washed it avoiding those 'need to avoid' areas, then sprayed Imron on it
04-25-2011, 09:56 PM | #10 |
Moderator
Re: Engine Paint
clean, clean, clean. Then apply POR 15 engine paint, done.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-26-2011, 05:07 AM | #11 |
Re: Engine Paint
OK, so what are the "need to avoid" areas?
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
04-26-2011, 09:11 AM | #12 |
Active Member
Re: Engine Paint
Carb, alternator, if you have a/c- cover the pump, dont spray directly at hoses and wires and plug wires. i didnt pay too much attention towards the back end of the block/intake on cleaning, mostly the noticable parts of the block that were shown that people would notice better. It cleaned up pretty well just by doing that. I also did not go for show quality just decent looks and i achieved more then that. Plus, if you still got the original aircleaner, sanding that a bit and sprayin black makes a world of difference. Good luck and hope i helped!
04-26-2011, 03:11 PM | #13 |
Re: Engine Paint
Duplicolor
04-26-2011, 03:11 PM | #14 |
Re: Engine Paint
04-26-2011, 07:01 PM | #15 |
Watch out for your cornhole !
Re: Engine Paint
I use POR15 engine paint. Over the years I've tried most all the aerosol engine paints and found them to not hold up to chemical exposure. POR is the only one I have found that will stand up to gasoline, oil, brake fluid, carb cleaner and the like without damage. I brush it on according to the instructions.
A 454 I painted with POR15 Chevy orange for my 70 stepside... A 327 for my 63 short bed, also POR Chevy orange...
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 04-26-2011 at 07:02 PM. |
04-26-2011, 10:19 PM | #16 |
Active Member
Re: Engine Paint
This is how mine turned out
04-27-2011, 08:15 PM | #17 |
Re: Engine Paint
hot tanked block sprayed epoxy primer and then vht rattle can engine enamel and still looks this good after 4 years
Fuzzy |
04-27-2011, 09:11 PM | #18 |
Re: Engine Paint
That is sweet looking motor...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
