04-25-2011, 08:37 PM | #1 |
ignition bezel ?
is there a trick or special tool i need to remove the bezel and the whole switch. i was able to turn mine about 2 turns and it wont turn either way now.
04-25-2011, 08:41 PM | #2 |
The Older Generation
Re: ignition bezel ?
Have you removed the ignition lock cylinder? It has to come out before the bezel will come off. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-25-2011 at 08:41 PM. |
04-25-2011, 08:44 PM | #3 |
no i didnt pull it out. i may have already screwed up then. is there any way to remove the cylinder if it wont turn to the acc position?
04-25-2011, 08:58 PM | #4 | |
What is keeping it from turning? LockDoc
04-25-2011, 09:02 PM | #5 |
i dont know it turned to the acc position one time right after i bought the truck and it hasnt turned any more. i need to replace the cylinder anyway because i want the doors to match keys.
04-25-2011, 09:29 PM | #6 | |
What year is your truck? Will the key turn to the on or start position? Possibly the key isn't going in all the way. I would try spraying it with some penetrating oil and wiggle the key up and down as you insert it. Also try wiggling the key up and down slightly as you try to turn it. LockDoc
04-25-2011, 09:50 PM | #7 |
Grandpa in the rustmobile...
loc doc is the man on this chris
you still have that cab? I lost my cell phone out my hole in my floor so im really considering a new cab..lol
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-25-2011, 10:28 PM | #8 |
it is a 71. it turns fine to start and run just not to acc position. i have sprayed it with pb before.
yea john i still have that cab. a buddy was coming to look at it 3 weeks ago and i havent seen him yet. first with cash gets it. |
04-25-2011, 10:30 PM | #9 |
the price still the same?..
04-25-2011, 10:31 PM | #10 |
we can work something out i need to free up some green.
04-25-2011, 10:41 PM | #11 | |
- Turn the key to the left as far as it will go and insert a straightened paper clip or stiff wire into the hole in the face of the cylinder and “gently” push the spring loaded pin in. Turn the cylinder further to the left to remove it. After you push the spring loaded pin in with the stiff wire and turn the cylinder further to the left you have to pull the wire out to finish turning it or it will bind. You can also turn it too far after you pull the wire out. That is when you have to wiggle the cylinder back and forth a little bit. If you wiggle it too much the pin will pop back out and you will have to start over. You should not have to put excessive turning pressure on it or push down hard on the spring loaded pin. Gentle and patience are the key words here... LockDoc
04-25-2011, 10:46 PM | #12 |
thanks locdoc i will try that tomorrow. the cylinder is worn badly the key will come out with the key in any position and about any key will turn it.
04-26-2011, 06:50 PM | #13 |
Sorry about your phone, but this is funny
1970 Chevy LWB - 305/350 In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's. |
04-26-2011, 08:24 PM | #14 |
Yeah, ol hubscub said 'the hole strikes again' my grandpaw lost his cane the other day out of it, yeah its that big
04-26-2011, 09:17 PM | #15 |
well i tried to get the cylinder out today. it turned left one time i put the pin in and turned further. when i tried to pull the cylinder out the key just pulled out. any other ideas. i have a parts truck with what looks like a new switch in it but no key for it.
04-26-2011, 09:57 PM | #16 |
I have some misc keys for GM..
Yeah stick a pin in the hole and turn left and maybe pull jiggle, it takes a bit of time maybe epoxy the key in there if you 'just GOTTA' get it out.??
04-26-2011, 10:27 PM | #17 |
Drill a 1/4" hole about 3/4" in. After that it will be pretty easy to remove the cylinder.
04-26-2011, 11:55 PM | #18 | |
LockDoc
04-27-2011, 12:07 AM | #19 | |
I just never gave it any thought. (Sorry...not meaning to Hijack the Thread).
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
04-27-2011, 12:36 AM | #20 | |
Unless your ignition switch was replaced with a '67 or early '68 switch it should have an accessory position. Try turning it to the left using the instructions above. LockDoc
04-27-2011, 12:45 AM | #21 |
Mine did the same thing. Took some experimenting, but putting some side pressure on it allowed me to get the cylinder out (my key would come out in any position also). New key cylinder at NAPA was $7, but it wouldn't match your doors.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
04-27-2011, 01:40 AM | #22 | |
If this IS correct, would it be the Lock Cylinder or the Switch that is bad? (Come to think of it, the swith IS kinda "sticky" when I start it up.) If I do get a new Lock Cylinder, will my local Lock Shop be able to key the ignition cylinder, to match the Door locks? Currently they all work with the same key.
04-27-2011, 10:12 AM | #23 | |
It could be either one, or it could be that the key is worn. If the key wears out the internal parts of the lock will wear with it. Since 99% of the time the key is turned to the "on" & "Start" positions the lock will continue to function that direction. When you want to turn the lock to the accessory position the internal parts are not worn in that direction so the key will not work. That's why wiggling it will usually get it to turn. If I were you I would take your key to a good locksmith shop and ask them to cut a new key to the GM factory specifications or + a few thousanths, and see if it will work. If your key is worn really bad it may be hard to do that though. Yes, any good locksmith should be able to re-key a new ignition cylinder to match the doors. If you can't find anyone in your area to do it let me know. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 04-27-2011 at 10:17 AM. |
