Old 04-26-2011, 05:53 PM   #1
byates2
byates2's Avatar
Crankshaft!!! Please help
I bought new chrome pulleys for the crankshaft and water pump! However the waterpump pulley seems to be an 1/8 of an inch deeper then the old one so the grooves arent lining up perfectly. I was wondering if it would be a bad idea to put washers between the crankshaft pulley and the harmonic balancer so it would line it up with the water pump pulley, and if that is a bad idea, does anyone have any ideas on how to make them line up the right way!?!?!?
1967 C10 Long Bed, Soon to have a 350
1997 Chevy 2500 454 BB
byates2 is offline   Reply With Quote
Old 04-26-2011, 06:09 PM   #2
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: Crankshaft!!! Please help
Take a gander at this FAQ
http://67-72chevytrucks.com/vboard/s...d.php?t=318240
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-27-2011, 08:27 AM   #3
biker3r
Good Info
biker3r is offline   Reply With Quote
Old 04-27-2011, 10:46 AM   #4
djgebert
djgebert's Avatar
I went to a hardware store and got a large washer, drilled four holes in it and made a homemade spacer. It is a lot better than a stack of washers behind the pulley IMHO, and is a quick/easy fix.
djgebert is offline   Reply With Quote
Old 04-27-2011, 12:23 PM   #5
stich626
x2
but if you look at the water pump.. the mount for the pulley is pressed on the shaft.. you can move it if needed..
stich626 is offline   Reply With Quote
Old 04-27-2011, 12:51 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
Ready made shims are also available for this, check out Summit Racing.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
