Old 04-26-2011, 06:30 PM   #1
m6z
m6z's Avatar
94-96 Impala/Caprice disc brake rearend questions
Does anyone know the length of the Impala/caprice 9C1 disc brake rearends? Diamater of the axle tubes?
Just thinking if its the same or a little narrower It might be cheaper to just swap a complete rearend instead of buying conversion axles and disc brakes for my 1968 housing.
Doug
Looking for a 67-72 short bed driver.....
m6z is offline   Reply With Quote
Old 04-26-2011, 07:07 PM   #2
jimmydean
jimmydean's Avatar
Re: 94-96 Impala/Caprice disc brake rearend questions
93-96 sedan
1566mm - narrow (9C1 - disc & drum & some other drum applications)
1598mm - wide (Impala SS - disc & B4U - drum)
I am looking to run the wide.
<edit> Not sure of the axle tubes, but you'll have to do perches anyway.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-26-2011, 09:57 PM   #3
m6z
m6z's Avatar
Originally Posted by jimmydean View Post
93-96 sedan
Thanks. Do you know where those dimensions are pulled from? outside to outside of backing plates? or?
It will be welding to a SD super lift wishbone setup, so I need to determin if I need to have SD make me a new set of axle mounts or if the ones I have will work.
Doug
