Old 04-26-2011, 07:53 PM   #51
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Re: HG's Adjustable Track Bar
That is mock up. I will eventualy be going with 18" or 20" rims on the back. It is sitting on paint rags in the picture. However it only looks like the shocks are below the rims, but the picture was taken from the floor looking up. They will not touch the ground when the tires are flat. I know this because my paint rags don't hold air for more than a couple of weaks..lol WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-26-2011, 09:31 PM   #52
bigguy69
dazed and confused
bigguy69's Avatar
lots of cool info here
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 04-26-2011, 09:55 PM   #53
pritch
pritch's Avatar
I am so going to build one of these. I've been debating which way to go and this just decided it. Very cool, HG!
Here are a couple pictures of my mock-up bar. I was going to use this to get things where I wanted them, then build a non-adjustable bar. I have a 3 1/2" drop.
This is a turn buckle we use to straighten foundation walls after we pour:
I just cut it off and welded a couple of pieces of 1/2" pipe to the ends:
(this is the one place I recommend using Chinese pipe-American has thicker walls and the bolt won't go through)
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 04-27-2011, 09:40 AM   #54
stich626
Originally Posted by mcbassin View Post
Hey, thanks for tweaking the model for the longer track bar. I appreciate the modeling skills. What are you using Solid Works, ProE, Catia? I use a few of these at work all the time. Mostly Featurecam for everyday use. BTW, I have to agree with you about the 66 back shock mounts much better design in my opinion.
well as seen as the shock isn't holding up the truck (unless you run air shocks or coil overs.
the 67 up mounts are plenty strong
stich626 is offline   Reply With Quote
Old 04-27-2011, 12:27 PM   #55
stich626
I have seen several of the 67 up mounts fail. probably more to do with worn out shocks or loose mountingbolts? Usually the hole elongates or cracks out. You have to admit coupling the shock with both sides is better than one? It just seems like much more robust design. Probably took longer to assemble in the factory though so they changed it. Who knows.
agreed,
but the mount wasn't/isn't the issue the cause is from lack of care..
like a emmissions converter, they don't fail, they are killed from something else up stream..
Old 04-27-2011, 12:42 PM   #56
lakeroadster
Using Autocad Inventor Pro
Last edited by lakeroadster; 04-27-2011 at 08:23 PM. Reason: Deleted discussion pertaining to lower shock bracket
lakeroadster is offline   Reply With Quote
Old 04-27-2011, 01:09 PM   #57
stich626
Really? When shocks fail they typically aren't as strong... they don't fail, get rock hard and break mounts. The point is GM went from a better design in 1966, to a weaker design in 1967. Look at shock mounts on new Chevy Trucks... they capture both sides.
And some of the aftermarket parts manufacturers are mimicking the weaker design in the shock relocation kits they are peddling. And they are selling them with shocks that are much harsher on suspensions, due to newer shock absorber technology.
  • If you use the truck to haul loads, the shock loads are more severe.
  • If you use your truck like a car the single mount will probably be just fine
Why settle for the weaker design? Or even worse, take of the stronger design and replace it with a weaker one?
and if the shocks where replaced when their service life was up. there isn't an issue,,
shocks don't hold up the truck.. air shocks and spring helper shocks are what kills 99% of mounts, yes the older set up is better never siad it wasn't..
but the 67-72 don't fail because of an engineering point..
it's use'n shocks as springs (air or spring helper shocks) or a locked up shock (frozen or bent ) not the mount..
Old 04-27-2011, 01:24 PM   #58
stich626
I guess we will agree to disagree.
thats fine..
but I gotta ask, why do you think a load in the bed (say for sh and giggles 1000lb) adds load to the shock.. the wheel/trail arm/rearend isn't any heavier.
nor did the spring rate change.. shock is only controlling the spring that didn't change.. it's still so many lb per inch
load only lowered the travel some..
what am I missing..
yes if you add shock valving that is set up for a 4 by 4 or
to run a road course , then ya, it stress the mount more than the engineers ever though of..
never mind the fact they never engineered the trucks to last 40+ years..
just wondering your take on all this..
Old 04-27-2011, 02:00 PM   #59
hgs_notes
GEARHEAD
hgs_notes's Avatar
Could you guys continue the debate via PM? I've been thread jacked.
hgs_notes is offline   Reply With Quote
Old 04-27-2011, 03:01 PM   #60
mcbassin
Still Learning
mcbassin's Avatar
Sorry HG, My bad. Didn't mean to muddy your thread.
Old 04-27-2011, 03:26 PM   #61
stich626
sorry
Old 04-27-2011, 09:28 PM   #62
lakeroadster
No problem. Discussion about Lower Shock Brackets moved to here: http://67-72chevytrucks.com/vboard/s...d.php?t=461618
