#151 |
Re: My 50 roadster pickup build
Lookin good,I'm going to print off this entire thread when your done!
#152 | |
![]() Join Date: Mar 2011
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
#153 |
I get ready to start working on mine I'm going to give you a land line call and bend your ear on some ideas I have going thru my head.
#154 |
When ever your ready, PM me and we will swap numbers. I'm not the brightest light in the pack, but I put out a little glow.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 04-26-2011 at 11:27 PM. |
#155 |
Going to be installing new latches in the doors. I chose to use bear claw type latches. I had used them before and they worked good. Make sure you buy good quality to start with, not the cheap crap.
My install is a little different from most, as I will be installing mine the opposite of most. This shows the opening I cut for installing latch.
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> Last edited by oldman3; 04-27-2011 at 07:07 PM. |
#156 |
This is the piece I made with the latch. I chose to mount mine in the back body door opening. I will show why a little later.
#157 |
Here everything is welded in place.
#158 |
This is the old latch opening in the door.
#159 |
Here it is with the striker mount in the door. This left room to reinstall the window channel in stock location.
#160 |
By mounting the latch in the body it allowed me to make up this manual button system for opening the doors. A hole was drilled in the cab corner, pipe welded to the hole in corner, and a threaded rod thru the pipe with a knob on the end. Push up on the knob and the door pops open. Part way up the threaded rod is a tee mounted, to this I added another rod that will stick out passed the interior panel for inside use. The top of the threaded rod is secured to the lever on the latch.
#161 |
If anyone wants more info on this just ask, I will make a drawing and take a couple of more pics.
#162 |
Doors on and working like a charm. Now I can work on the gap a little more.
#163 |
I decided I did not want any of the vent stuff on the cab. The drivers side was welded shut. This view shows the passenger grill cut out.
#164 |
Not a good pic, but shows the opening patched with the old grill beside.
#165 |
This was someone's ideal of a hole for an antenna, or something???
#166 |
Old area cut out and new patch panel made and installed.
#167 |
Tomorrow we go back to the doors for more mods.
#168 |
Post #134 shows that knob pretty good,you have to look for it.I like that idea!!
#169 |
Good eye, yeah it works real easy.
#170 |
Here I'm cutting off the top part of door. Cut was made at the top of the body line, this will eliminate where the old window surround was installed. I had to remove this so it was level with the rear of cab.
#171 |
This pic lets you see what I was referring too. I also had to rework the cab body line to line up with the door better.
#172 |
By removing the top part of door piece (left) I had to make up a new piece that would stiffing up the top of door, and have a place to attached window felt. The piece on the right is my new piece.
#173 |
Not a good pic, but if you look at the opening you can see the 1/8" steel piece that was welded in.
#174 |
Now the inner and outer height is the same. I also modified the inside garnish molding to extend back and tapper to an end.
#175 |
This was the windshield header and how the door matched to it. Once I start making the top this will all change.
