Old 04-27-2011, 06:06 PM   #1
willstruck
Realized the build sheet in the glove box
Yesterday, I realized the build sheet for my truck was in the glovebox. When I bought the truck, I was told it had a 350 in it. It's an automatic. Manual locking hubs.
Build sheet says it's a 305, 4 speed manual transmission, and automatic hubs... So, how can you easily identify if it's a 305 or 350? Also, any telltale signs that the truck was originally manual and converted?
'85 k10 long bed, 6" lift. 35" tires. 350, Edelbrock intake/carb, headers, dual exhaust. Automatic.
willstruck is offline   Reply With Quote
Old 04-27-2011, 06:11 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Realized the build sheet in the glove box
Compare it to the VIN number. Auto and engine size will be in the VIN. Check the emissions sticker. What does it say? You have to decode the engine block number to know for sure without opening it up.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 04-27-2011, 08:09 PM   #3
bikes&bowties
bikes&bowties's Avatar
There will be a hole in the floor for the clutch linkage... Also the hump. But that's changeable
bikes&bowties is offline   Reply With Quote
Old 04-28-2011, 08:13 PM   #4
willstruck
There is a hole for the shifter. It has a cover bolted over it, so I didn't know if they just used the same hump or not. I'm gonna check the casting # on the engine when I get a chance, and see if it's a 350 like I was told or the original 305.
Old 04-28-2011, 08:34 PM   #5
bigblock73
yeller
bigblock73's Avatar
Keep in mind, the glove box liner that has your spid could have been changed out...and not even be for your truck...compare it to your dash VIN before you spend any time chasing your tail.
bigblock73 is offline   Reply With Quote
Old 04-28-2011, 10:33 PM   #6
willstruck
Thanks, you got a point there...
